Question about Garmin GPSMAP 60CSx
Garmin 60CSx - Cant find satellites
My new Garmin 60CSx dont find any satellites. What could the problem be? I appreciate any proposal to solution.
Best regards
Nils
  • Anonymous Oct 21, 2008
    my unit was working fine and then nothing worked well for two days now wont locate satelites
  • wodz Jan 02, 2009
    I have the same problem that my Garmin 60CSX shows GPS SWVersion 0.00 and will not acquire satellite. I have reinstalled system 3.7 and chip set, but problem is still the same.
Had the same problem, lost the chipset firmware, unit showed software version 4.00, chipset 00.0. Spent many hours trying to fix the problem.
Seems many people are having similar problems since using the webupdater. My unit became blank on the satellite page after update.
found many "solutions" on the net, none worked for me, resets,master resets,uninstalling usb drivers etc,etc.Was on the point of sending the unit back to Garmin for a very expensive service, contacted garmin who said they had never come across this problem !!!!.
Problem seems to arise from pressing the light button at an inappropriate time in operation.
This solution worked for me, check out this file and download
http://www.gawisp.com/perry/gps60/GPSMAP60CSx_250.exe
extract file to new folder
connect garmin, and run updater in the new folder.
following this procedeure, all appeared ok--ran the webupdater and installed latest soft/firmware.
here is the chipset files to try, although suggest leaving well alone if you aquire satellites with any software version.
http://www.gawisp.com/perry/chipset_firmware/Type_G/
Good luck !!!
Posted on Sep 22, 2009
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Posted on Jan 27, 2008
My GPS map 60CSX is not acquiring satellites. It was working fine until most recent power up.
Posted on Jun 02, 2008
My Garmin 60csx won't locate satelites
take a look on the old messages and You will find a solution posted for me.
Sep 30, 2014 | Garmin GPSMAP 60CSx GPS Receiver
Gps 60csx don't get satellites signal level
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
Dec 08, 2012 | Garmin GPSMAP 60CSx GPS Receiver
Need satellite
Go to garmins site and download the fix for this issue. Have fixed several of these. They have the download there. I just fixed one the other day.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Sep 15, 2009 | Garmin GPSMAP 60CSx
While on a road trip my 60csx quit acquiring satellites.
Try downloading and installing V3.70 from here http://www.gpsinformation.org/perry/gps60/
make sure you use the right one for your GPS
Jul 03, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Sep 17, 2007 | Garmin GPSMAP 60CS GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CSx Logo
1,133 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
