Question about Dell (04U621) for Latitude D600, Inspiron 600M Motherboard
Motherboard Dead Hello I have a Dell Latitude D500 Laptop. It had no power when plugged into the ac cord. I took it down to the motherboard and discocvered a couple of burnt out components, I believe they are called power inductors. The numbers on the components are 3R9 6R8 & H34. Can anyone tell me if there is a place I can find the description of all the components of the motherboard,. I would really like to fix but not sure how to proceed. Am mechanically inclined and can solder new components in. Any info would be greatly appreciated,. Thanks Tom Happy New Year!
  • N-Gen Feb 25, 2008
    I have the albetron P4M800-775 series motherboard. It seems to be quite dead even if all components are connected. only indication of power is the power led burning and that's it, not even the CPU fan is running. It seems that nothing else is recieving power due to dead motherboard. I have tested the power supply and there's nothing wrong with it. All other coponents are in working state for they have been tested as well.
    Novelist:
  • 108 Answers
Hi Tom,
there are plenty of basic component overviews in the D500 Service Manual, but I don't believe you're looking for that specifically. What you're looking for is a circuit board schematic, to see the exact paths.
Unfortunately, Dell uses a strictly proprietary wiring scheme, so you'd have to call them directly. Although personally, I'd advise against repairing the board yourself, even with your experience. I think It's quite obvious from the burnt out components you've found that the board was subject to abnormal voltage levels, most likely from a power surge. There's no telling what path the electricity took, and how many components it's damaged. replacing those two inductors (if they are, in fact inductors) could fix the problem, or it couldn't... it's hit or miss at best. It's for this reason that most techs just replace the board instead, soldering it only if the problem is a leaky capacitor or two.
Posted on Dec 31, 2007
  • 3 Answers
Tomk161, heres some information that may help you.
the firt two components are not coils. 3r9 is a 3.9 ohm resistor, 6r8 a 6.8 ohm resistor. at this point im not sure what you mean with the punctuation etc" AND SYMBOL? amp; h34". do you mean these components are located at grid h34 on the board, or is this another componet or two? the wattage of the resistors is most likely only 1/4 watt or less. infact if they are surface mount (flat soldered driectly to the board with no wire leads) they are probably 1/10 w or less and most any surface mount resistors of proper resistance will work, regardless of wattage. give me more information on any other components you dont recognize and i may be able to tell you from 50 years experience as an electronics tech what they are, eventhough ive never seen the board you speak of. -daag55
Posted on Nov 18, 2008
  • 95 Answers
Only solution I have ever found is googleing the chip numbers and looking for a supplier of these exact chips. As for soldering them it is not that hard and I have had some success with it. Might be better to pick up a used board on Ebay if they are not too expensive. Sorry I have never found any schematics on the internet for laptop mother boards.
Posted on Jan 01, 2008
Hi Tom,
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
DC output plug problem
Not trying to split hairs here, but the DC output plug would be the plug on the end, of the AC adapter (Charger), that plugs into the DC Power Jack.
Just trying to help when you refer this to someone else.
The port on your laptop that the plug of the AC adapter (Charger) plugs into, is the DC Power Jack. (May be labeled as DC IN on the laptop)
The entire motherboard needs to be removed, and in your hand.
http://support.dell.com/support/edocs/systems/latd400/smen/index.htm
1) FIRST thing;
Buy and wear an ESD wrist strap. Connect it's alligator clip to a good ground source.
This is one example of a ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
(The wrist strap itself has a bare spot, and a piece of metal in the wrist strap contacts the skin of your wrist, through this bare spot. There is also a 1 MegaOhm resistor in the circuit )
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
(Processor, motherboard chipset, Ram Memory, harddrive, etc)
Using an ESD wrist strap prevents this.
{ I connect the alligator clip to an unpainted surface, of the metal frame of an open, empty desktop computer case.
Not everyone has one of these babies laying around.
If the table you are working on has metal table legs, connect to an unpainted surface, of one of them.
Otherwise place a large metallic object on the table, and connect to it.
Perhaps a large metal serving tray (Unpainted), or a large metal knickknack. (Unpainted }
2) Second:
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, substitute with a clean egg carton. Label each egg holder.
SOME screws look VERY similar to other screws.
DO NOT mix them up.
3) Make a record as you disassemble. It's nice to have a Service Manual, but better to also have a personal record you created.
Make notes, and drawings. (Make them legible so you can understand them later)
Perhaps use a digital camera, or video camera also, if available.
(Use GOOD lighting)
Now you are ready to begin.
http://support.dell.com/support/edocs/systems/latd400/smen/sysboard.htm#1084976
http://www.insidemylaptop.com/replace-cooling-fan-dell-latitude-d600-laptop/
The above is not the Dell Latitude D400 series, but I feel the pictorial guide will help.
http://www.insidemylaptop.com/remove-motherboard-dell-latitude-d500-laptop/
Again, the above is for a Latitude D500 series.
One of the toughest things to remove, IMHO, is the Keyboard.
The Keyboard Cable disconnects FROM the motherboard.
If the connector on the motherboard is not opened correctly, it can be broken.
This means motherboard replacement, usually.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 01, 2012 | Dell Latitude D400 Notebook
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
Dell Latitude D500 won't switch on. Lights come on for about 10 seconds then automatically switch off. Plugged into mains and battery charging light is on.
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 21, 2010 | Dell Latitude D500 Notebook
Dell latitude d500 wont charge.
If the original batteryand the system works on AC power, then replace the battery.
If the battery has been replaced, then it could be a motherboard charger failure
Jan 25, 2010 | Dell Latitude D500 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
New hp laptop battery will not charge w/plugged in AC and turned
You probally have a dead motherboard port that charges the battery.
Sep 26, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
573 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
