Question about Mitsubishi WD-52631 52" Projection HDTV
Green Blinking Light
I have the green blinking light on this unit. I have tried holding the menu and input button...but all it does is blink green...I get no repsonse/error code. I would appreciate any help.
  • ladyshaggy57 Dec 29, 2007
    This happened to me. 65inch misubishi had the blinking green light on for four days. Then I left my surround sound on overnight and the next morning the green blinking light was off. Tv working fine. Just weird.
  • moparelvis Dec 29, 2007
    hmmm well me leaving my surround sound unit on will not fix this problem...if anyone knows how to fix this I would greatly appreciate the help...again I cannot check to code...holding down menu and input does nothing...i just constantly get the green flashing light......
THE SAME THING HAPPENED TO US TODAY AND IT IS BOWL WEEK!!!!!!!!!! urgh!
Posted on Dec 29, 2007
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52631 52" Projection HDTV Logo
225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
