Question about GE WCVH6260F Front Load Washer
GE WCVH6260 Front Load Washer
Our 6-month old washer goes through the initial wash cycle but does not spin the excess water out at the end of cycles. Many minutes before the end, the Pause/Start button light starts flashing -> when pushed, the washer starts water flowing into the drum for many minutes but does not ever get to the spin cycle.
  • 1 more comment
  • David Steinhorn
    David Steinhorn Dec 29, 2007
    I did this already this morning and it continues to give me the flashing start/pause light before the spin cycle and then hangs without ever going into the spin.
  • powderfield Jan 31, 2008
    I have the same problem. Initial cycle runs and then never goes into the spin cycle. We took off the front panel, removed and cleaned the filter - found plenty of stuff to clog it - thought we had it. Put it all back together but still have the same issue - goes through the initial cycle then the pause button flashes. When pushed it slops to one side, then the other and then sits for a while, then flashes the pause button again. Is there possibly something else that could be clogged besides the filter to cause it not to drain or what else might we try? Calling our local service has proved to be a joke. Can't even get them to call us back.
  • jkurpius04 Nov 09, 2008
    I have the same problem - machine pauses mid-cycle won't spin and the water will not drain. I put in the rinse and spin cycle (18 minutes) and nothing happened except the drum turned one way then the other. I watched the counter go from 18 minutes to 1 and nothing happened. No water went in, no pumping out of standing water, and no spin cycle.
    If someone can be more specific on how to get to the internal filter I would be grateful.
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
  • bigman812 May 31, 2009
I had the same problem. I read this forum and started to investigate. You simply take the 3 screws out from under the front lip. I put a cake pan under the lip of the drain and unscrewed the filter to take out the stinky water. Once it won't unscrew anymore pull the filter out and clean. Replace the same way you took it apart. ....and no, it's not in your manual for this model
Posted on Dec 13, 2008
Thank you ...thank you...thank you. i never knew that there was a filter..as ge manuel says nothing about that. got 2.75 in change, a few rusted screws and assorted other **** out of it. runs like new
Posted on Nov 27, 2008
  • 4 Answers
UPDATE: Turns out my filter was clogged and the pump burned out. I cleaned the filter and still no pumping. I replaced the pump and now the machine works like new - cycle times are correct. Bought the pump from GE and then haggled with them to refund the money, and they did.
Posted on Nov 29, 2008
This was amazing, removed the three screws to the front panel, unscrewed the filter (have a cake pan ready for the water and stuff) cleaned it, found $1.26 a necklace and a ton of lint...hope this is where the stagnite odor was coming from. Thanks for the help, it took about twenty minutes. It was harder to put the screws back in the front panel, than anything!
Posted on Mar 19, 2011
Mine did the same thing and it's because your hot water faucet needs to be on. I kept mine off because it leaked, so I have to turn the hot water faucet off and on each time, But the washer goes thru the cycle now. Only thing is, I cant wash in cold only. can't figure out why
Posted on May 22, 2009
Yes I have to agree with the previous posting. I had the same problem and the service tech for GE came out to repair. It is exactly what the previous posting says. That is what the tech did and agreed it is a common problem.
Posted on Jan 09, 2008
Easy, I had same problem. just need to take the front panel off and unscrew the filter/ trap clean it and put it back, the machine will run wonderfully again. you have to do this every couple of months
Posted on Dec 29, 2007
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
When washing a load the machine is not spinning.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
My GE front loading washer Model WCVH6260 does not start the rinse cycle spin. It has a motor sound and some water seems to be draining but the rinse cycle does not spin and the motor continues to make a...
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Oct 01, 2009 | GE WSXH208A Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WHRE5550HWW Excessive Shaking in spin cycle
Replace your stablizers, one of them has broken.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Washing Machines
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WCVH6260F Front Load Washer Logo
1,777 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
