Internet router will only work with one computer turned on.it worked with bell but not rogers
Internet router worked for two computers with bell internet. switched to rogers cable you can only have one computer on at a time
  • Anonymous Mar 15, 2009
    2 macbooks and an apple extreme wireless router.  For some reason both receive the signal but only one actually works.  Also have other wireless devices that cannot connect.  Any ideas?
  • 35 Answers
Cable sees the mac address of the pc that you hook up and you need to set the router up as a dhcp server and clone the mac address into the router. that will make it work
Johnlgrn
Posted on Dec 31, 2007
My internet connection keeps dropping or becomes very slow. When I disconnect and plug it back in, it starts working for a while and then I have the same problem. I connected my rogers internet directly,...
Sorry to say, but it sounds like your router is toast. Not really a big deal. Get a new one. The 624 wasnt a fantastic router to begin with. A new router will far exceed the capabilities of this router anyway. Hope this helps : )
Jan 07, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
Can I get my d 615 to work with Rogers high speed USB stick?
The Rogers high speed USB stick will only work when plugged into a computer.
The stick does not work the same as a regular wireless card and so you can not use it to connect to your router.
You will need to have a seperate wireless network card to connect to your router, then your computer will be able to connect to both the network and the internet.
Thank you,
Pat
Mar 13, 2010 | D-Link DIR-615 Wireless Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not get connection to the internet with my MOTOTOLA WN 825G
at the command prompt (dos black screen) type ipconfig /renew this should reset your local ip address for the new Bell router. Your laptop is trying to use the settings from the old router.
Sep 01, 2009 | Motorola 802.11g Wireless Notebook...
The light of internet is orange,not yellow.
The router should have reset button on the back. This will reset it to factory defaults. If you have an ISP that gives you internet without a username and password like rogers then you should be good to go. If your ISP is like Bell then you will need to get into the website of the router and configure it.
Nov 28, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Resetting password ? Bell told me I would have to change my router password
The router has a built in configuration chip that allows you to work on the router from your computer. This is called Web Admin Console
Your computer's IP address is 192.168.10.4
The router's address is by default 192.168.10.1 from factory. (AKA the GATEWAY.. like gateway to the internet) This can be changed but it is highly reccomened you leave it default.
To access the configuration of your router
Go to internet explorer and type http://192.168.10.1 hit enter.
You will see a window with a webpage of some sort that has the Motorola logo somehwere.
Look for PPPoE or password setting... you should be able to navigate from here..
A word of advice.. enter your password, save settings, slick or or something like that..
then restart router (pull power, wait 5 secs, and then plug back in) The router has to talk to Bell for a bit to make sure it knows that you're authorized to use the DSL line.
Best Wishes..
www.techvisitor.com
Nov 03, 2008 | Arris Wireless G Broadband Router (wr850g)
Rogers Music Store/ Media Player
my phone keeps on showing i only have 6 songs when i have 179 songs on it sometimes it works and sometimes not
Apr 03, 2008 | LG Shine KE970 Cellular Phone
Computers & Internet Logo
414 people viewed this question
Alun Cox
David Payne
David Payne
