I have an Ionic Breeze SI730. It will not turn on. I looked inside and there are two wires that run from top to bottom, one of them has come off its connection at the top and is laying on the bottom. Today, one of the ball bearings fell out while I was blowing compressed air inside to clean it. Where can I get the wire re-attacheed and the ball bearing replaced?
You could try some appliance repair shops. If you are able to solder the loosen wire , do so. but the ball-baering coming offf indicates a serious problem within the motor. Look in your yellow-pages for electric motor service. They could help replacing the baearing. But do not be surprised if you didn't get the bearing replaced. Those small appliances are meant for "disposable" use.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharper Image Ionic Breeze 3.0
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and...
(More)
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and lead go through hole in wall along wall in next room need to know how to remove whole unit thanks
i have a sharper image weather station LM 516 and i need the radio controlled outdoor sensor. can...
(More)
i have a sharper image weather station LM 516 and i need the radio controlled outdoor sensor. can you help me?
It stopped working and it worked the day before.It was clean and cleaned it a week ago,so it wasn't...
(More)
It stopped working and it worked the day before.It was clean and cleaned it a week ago,so it wasn't wet.The outlet has power. The two wires are perfectly fine. I cant see any burn marks looking inside of it. How do I pop it apart so I can check other internal parts I can't see. Everything i can see looks fine. I would really like to know how to pop it apart without really messing it up?
