Question about EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g / Dual Band / 400mW / Wireless Access Point
Senao 8610 not working
i am setting my senao 8610 by web
then i reboot the device i cant connect to device and cant ping ip address of device
only power led and lan green and the w.lan led is not blinking
  • 3 more comments
  • Mehdi_sh Dec 30, 2007
    yes i am save my setting when reboot
  • Mehdi_sh Dec 31, 2007
    i dont any problem with my dsl line or oprating system , i hav problem with my senao 8610 that is not working only power and LAN led is working and i cant connect to senao8610 by webbrowser , i use angry ip scanner and it cant find ip address of my bridge , i think my bridge memory is down and dont load frimware after i reboot it
  • nicompt Sep 25, 2008
    reset senao noc 8610
  •  Anil Shrestha
    Anil Shrestha Nov 28, 2008
     cant access ecb 8610. it doesnt rest also. when i press reset nothing happens and w-lan led is not on too.
  • niemand101 Apr 16, 2009
    exactly same problem hold reset for 15 sec doesn't help. Send it back to engenius and waiting for there answer.
  • 4 Answers
I cant access ecb 8610. it doesnt rest also. when i press reset nothing happens and w-lan led is not on too.
Posted on Nov 28, 2008
  •  Anil Shrestha
    Anil Shrestha Dec 03, 2008
    I have ecb 8610 , reset button dont work,how can i reset from another way? can i join serial-there is no serial port also?
  • 35 Answers
Are you saving your settings when you exit the setup screen?
Posted on Dec 30, 2007
  • John Green
    John Green Dec 31, 2007
    How are you hooking up to the internet? Cable or PPOE which is dsl phone line? Do you have a static ip address or a dhcp address? Are you setting the ip in the router or are you leaving it as default? What is the address? What operating system is this?
I can connect to my own WiFi but it will not connect to the server
Hi Mary,
Your Q. is not clear. I assume your internet is working but you cant connect to the local server on your network right? IF so please try restarting your router and see if it helps. Thanks .
Jan 02, 2018 | The Computers & Internet
I can't enter the web from or how i can enter web setting AP senao 8610S? what sould i do?
Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e.
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway= instead type in
Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
I want to reset using RS323 port , i forgot its ip adress
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I forgot ip address of my EOC 8610. how do i
Try address in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
My computer says Im connected network but cant get on internet
Same router I use. It sounds like you have an option in your router that is blocking you from accessing the internet. Possibly a bad DNS server or you have accidentally restricted your computer from accessing the internet via filters.
What I would do at this point is go through router, option by option and write down any custom settings you might have. After you have them all recorded, hard reset the router. This can be done by pressing the pin hole button on back of router for about 10 or so seconds. Doing this restores your router to factory specs.
After back to factory specs, try connecting to the internet before implementing any type of security. If it works then one by one enter in your old settings that you have written down from the above step. After each setting change, try connecting to the internet, when you get back to not being able to connect, you found your rouge setting.
More thoughts on this issue:
Try connecting directly to your modem via a wired connection. After you wire the connection, reboot your modem and try accessing the internet. If it doesn't work, then I would call your ISP to see if there is anything wrong with your internet (unpaid bill, area outage). If it does work, then rehook your modem to your router. You will need to first reboot your modem then router after modem syncs up.
The rebooting of devices is important. When your modem boots up, it leases an IP to the MAC Address of the connected device. If you have not "cloned" the MAC addy, then each device has a different MAC addy. The modem will not allow access to the internet if the device connected has a different MAC address than what it leased the IP to. I would actually try this method before a hard reset of router.
If your modem has battery backup, you will need to unplug the battery along with pulling the power wire to perform a reboot. The router can be rebooted just by pulling the power wire and plugging it back in.
Hope this helps, sorry for it not being in order, the reboots came to mind after I started writing.
Sep 14, 2009 | Linksys Wireless-G WRT54G Router
Noy finding ip address senao wireless AP
Hi. Here is the manual.
Set your PC to use the static IP, netmask
To login to the web manager, go to Leave the username and password blank. You can now configure the device and assign IP address etc.
Jul 18, 2009 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Can not access Dlink DNS313
When you said you tried resetting, did you mean you clicked on the reset button inside the hardware or did you mean you just rebooted?
* If you clicked on the rest buttion, then you need to configure again from scratch. Not sure if your data will still be available though.
* If you just rebooted, then the problem may lie in your LAN configuration. Do the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
Dec 29, 2008 | D-Link DNS-323 (DNS323) Hard Drive Array
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Finding of IP for the senao 3320 ext.
repair center, visit :
Oct 03, 2008 | SENAO NL-2611CB5 PLUS (NL2611CB5PLUS)
Two out of 3 computers not talking
first make sure all pcs are on the same network name, usually either mshome or workgroup, to check this go to my computer>right click>properties then look at computer name tab, if any are different than the network you should be named as click change name, save and restart. Then go to each computers network adapters properties and go to the TCP/IP line nd click properties again and check that the cards are set to obtain ip address automatically and click ok, because if you hve used the wizard it would have changed your pc's ip addresses. Next go into your routers settings by typing it's ip address in your web browser (eg, depending on the router, refer to manual) and look in menu for DHCP and make sure this is enabled so as to automatically asign your pc's an ip address. If you are struggling for any of the pcs's to obtain an address, click Start>Run, then type ipconfig /flushdns to clear all ip and dns addresses.
May 01, 2007 | NetGear DG834G Router
EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g / Dual Band / 400mW / Wireless Access Point Logo
657 people viewed this question
Top EnGenius Computers & Internet Experts
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
