Question about HP LaserJet 2550L Printer
Drk black page print
1st i got some mag. spot on each print
so 2nd i clean all tonner cart. ith blowing machin
but steel problem not solve
3rd i open whole drum unit & clen the assembly i clean wastege chember
& install in printer
after this print was gone
first the paper jam in devlop[er roller i clen the paper jamming & put the self test agin
but the only blake print is come
so plz tell me here my mistake was done
    Problem Solver:
  • 25 Answers
Are all the colors in the correct slots on this printer?
Posted on Aug 14, 2008
Epson tx700w black ink doesn't printing well.
1st a fall u must purchase original cartridge 2nd clean the head 3rd print the alignment page.
Be careful when u clean the head.
It is better if you use contact cleaner for head cleaner.
IN SHA ALLAH the problem will
Oct 06, 2017 | Epson TX700W Series
New ink colour printer not printing black. Prints all other colours but not black when print tested
Hi there!
If the test page from pc or the machine test page doesnt show black, what you can do is to clean the printhead. To do that press the Ink Management button on the control panel and select cleaning press ok then press the up or down arrow key to select Black press ok and press Black Start. After the cleaning process print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times.
Hope this helps Please rate if it worked Thanks!
Mar 30, 2011 | Brother DCP-585cw All-in-One Wireless...
When printing or copying I m getting thick black
First try running maintenance to clean print head on your machine.
If that does not solve your problem replace the ink carts OR Toner cart.
(I am unsure which you have as that was not specified)
Jun 08, 2009 | Brother DCP-8060 Laser Printer
Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Jun 04, 2009 | Lexmark E232 Laser Printer
Black smudges on back of sheet
I don't have this but I try to solve your problem :
In the printer and fax, right click on your device name, choose maintenance and run Cleaning, Deep Cleaning, Roller Cleaning and Bottom Plate Cleaning.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Cant solve puzzle 100 in professor layton cant go on im desperate
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Print quality on oficejet all-in-one hp d135: Re: How do I "clean" / prevent background printing from a prior print request? Problem: 1st print OK; 2nd printed 2nd page with printing from some other source...
Go to the printer's Properties and cancel all printing jobs that are in queue. Switch of the Printer. Restart it.
Take print of any document and see if problem is solved.
Dec 02, 2008 | HP OfficeJet D135 All-In-One InkJet...
Changed all 3 colors and black---Red not printing
Print is brown: mingles yellow with bk and cyan and red.
Did you use generic ink? You have to use a set of original brother ink carts: dinsert the original carts. press menu then start b/w copy then fourtimes arrow-up. when machine is in maintenance mode press 7 then 6 then 4 then start b/w copy. machine will initiate the carts and do some power cleaning. whnen finished press 7 then 6 then 3 then start b/w copy. machine does a power purge. leave maintenance by pressing 9 then 9. Do run a test print. If you cant see any mag. do the power purge two days later. If your not lucky then (you cant see ANY mag squares on test print) the head is defective and needs replacemnt.
Mar 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
Aug 11, 2007 | Kyocera Mita FS 3800 Laser Printer
HP LaserJet 2550L Printer Logo
52 people viewed this question
Ben Johnson
