Question about RCA D52W19 52" Rear Projection Television
Help me i have a green spot or half moon shape in middle of my picture
    Genius:
  • 1,030 Answers
THIS is what is commonly called a crt burn. could be one or more of the 3 crt. i rather difficult and expensive repair. the tubes will have to be replaced
Posted on Dec 29, 2007
How do I get the part shaped like a half moon to release the blade from the juicer:
Fit the stubby metal bits on the half-moon into the holes on the top of the blade. Hold the half-moon firmly and exert pressure to turn it to the right. The blade should unlock.
May 09, 2014 | Jack Lalanne Power Juicer 250 Watts
Blinking green light
check the motor make sure it move's smoothly. if you hear ticking wile its moving the bushes have warn away. and will need a new motor if it is fine check the wire to the board there is a 3 pin chip half moon shape check this.
Oct 25, 2013 | Electric Traxxas Stampede Xl-5 Rtr ...
Green half moon at bottom of screen, then no picture or sound
likely a convergence problem which has gotten worse
May 14, 2012 | Hitachi Televison & Video
Replacing camshaft position sensor, Sable 2003,Ohv
usually if the magnet in the sensor comes out it destroys the cam position shaft,(it should have a half moon shape when u remove the sensor from the cam pos/oil pump drive. if the half moon is damaged or missing u must replace the cam pos/oil pump drive, and yes it is timed with the engine. wot i have done is try to locate where the half moon was on the drive it usually leave a trace of where it was. now index where the half moon is at remove hold down bolt and remove the driver assy. install the new drive, clock the half moon shaft to match the one u just removed once u get the half moon shaft where u want it and the oil pump rod alines and the whole housing is down install the hold down clamp. now to get rid if that check engine lite youll have to plug a scanner in and look at the live data adjust the cam position till u have plus or minus 2 degrees
Mar 18, 2010 | 2003 Mercury Sable
My 60v710 Hitachi has huge green spot in middle of the
light engine Call Encompass Parts 1-800-638-3328 or Try UED 1-800-648-6657
Jan 19, 2010 | Televison & Video
Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
May 04, 2009 | Kirby Heritage II Vacuum
Moon
The lens elements or aperature have become misaligned or stuck. You might try selecting various focus and digital/analog zoom mode settings.
May 31, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Red spot in the middle of the screen
You most likely have a burn in on the surface of one of the picture tubes. What you need to do to confirm this, would be to take off the front screen, and with the set turned on, look directly into each one of the lenses, and see if you see a mark on the green or the blue tube. if this is the case, and I am pretty sure it is, the picture tube will need to be replaced, but this set is not a young thing, as the green faint lines is most likely a bad capacitor in the screen drive circuit. If the picture tube is indeed burned on the surface, most likely be better off buying a new TV set. Good Luck
Jun 25, 2007 | Toshiba 42H83 42" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
