My washing machine water levels are messed up. If i put it on small load it pretty much fill the machine up. If I put it on large load it fills till it floods my laundry room. Could i fix this problem my self.
Plug off the wall; open up behind. You will find a thin hose running from the switch area to the outlet area. Carefully try the hose clip to remove the hose from the top, blow into it - it should be free. Free it by removing anything blocking it, usually some dirt from below; the hose should not be kinked. Refix. This is the water level hose, which signals the machine to start or stop water.
Change the fill valve located where the hoses hook up
