Television problem TV has been working perfectly and today when I turned it on there is absolutely nothing at all. Not even a light to say that the TV is on.
  • Tinman238 Jan 06, 2008
    Exacty the same problem: TV has been working perfectly and today when I turned it on there is absolutely nothing at all. Not even a light to say that the TV is on.
Problemmes de la comande
Posted on Dec 29, 2007
  • 149 Answers
Hi there, 1st problem no light indicator means power supply section problem, it maybe a horrizontal section problem too. identify the troubles by section. check first the power supply section then the horrizontal section. try to test some parts. ty
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
TV turns off by itself after 35 seconds of being on. Indicator light flashes red endlessly.
The TV is going into protection mode. Could be a problem with moisture. Can you try warming up the rear with a hair drier? Ensure that you do not apply too much heat to avoid damage to plastic parts. If you can remove the back cover (after unplugging the power outlet and switching off the TV), try doing in on the entire PCB, if you suspect moisture is the problem. Please do not touch anything in the board by bare hand as there would be high voltage charge in capacitors even after switch off. If it does not work, this might need attention of a qualified service technician
Jul 11, 2012 | LG 42LD450 42 in TV
HI i have a JMB LCD TV MODEL 42883 today it started turning its self, on and off standby,the standby light is flashing on and off i`ve even tried taking out remote battery but nothing works sometimes...
hi I have a JMB LCD TV MODEL 42883which has only worked for one week b4 the screen was cracked by accident everything else is perfect.would solve one of your problems your having with your tv.will sell it at reasonable price.07719651554 if interestd
Mar 01, 2011 | Televison & Video
Panasonic Viera TH-46PZ85BA Will not switch on
Yes, the unit has a problem. I work for Panasonic in New Zealand and the unit needs to go in for servicing. 10 flashing lights means a fault has occurred (if I was at work I could tell you what 10 flashing lights means).it should be repairable.
Sep 26, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Magnavox 20MF251W won't turn on at all
my tv is not rurnine on the standby light is on
Aug 27, 2007 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
Lost all sound
I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in cas it has been zapped by lighting good luck
Aug 26, 2007 | Protron PLTV-32 Television
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
