I solved a problem exactly like this a couple of weeks ago. Thee thing is, the fan spins at a certain amounts of rpm that would result in the sufficient amount of cooling needed for your system.
There is some programs that you can use to reduce the speed at witch the fan runs, thus reducing the noise, but then the system will not get sufficient cooling and the cpu might overheat.
The only solution i can give you that will not compromise the overheating of your system is to clean the fan you are using at the moment, i use compressed air. Hope this can help you.
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if...
(More)
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if its software i have to download or its internel and i cant find it in my control panel
i have changed computers and am unable to access jigsaw puzzles purchased in the name of...
(More)
i have changed computers and am unable to access jigsaw puzzles purchased in the name of morag.milne@dsl.pipex.com when i type in reg key it is refused and i am unsure whether i should type the number"0" or the letter"O"
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system...
(More)
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system menu but then image error pops up with a black screen. cannot use laptop i think i may have lost data. pleeeeaaaaase can somebody help.
