Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hampton Bay 54 In. 5-Blade with remote control at wall.
I have two hampton bay with remote control. One work very well, but the other one only work in Low Speed works to slow, in Medium Speed works at lower speed than normal and in High Speed works lower than Medium speed.
My email is bobby114@hotmail.com
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Posted on Apr 08, 2008
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Unable to get fan to respond to remote Hampton Bay 54".
There is most likely a wall switch which you will need to ppush to the on position to send power to the fan, then the remote will do as it is supposed to do. If you find that it is not the wall switch, then I would check the electrical panel for a circuit breaker that has kicked partway off or blown fuse.
Apr 26, 2009 | Universal Remote Control Hampton Bay...
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay 54'' fan stopped working
make sure the main switch is on ,also if there is a fan switch make sure its on before using remote
Jan 04, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay ceiling fans
in order to help you, i need to find out the model first. you can find it out at the top of the circulating fan which has a sticker, from there we can find out the model and the appropiate serial number , remote are available on line depends on the model number
Dec 21, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote needed
If you talk to Fantasia Fan people, they may be able to help you. I've had spares from them, & they were helpful.They also supply a wall mounted, wired controller, but it needs an electrician to do the wiring. The plus with hard wiring is that it doesn't have a wireless controller pack to go wrong.
Dec 18, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Diminished light
When our 2-year-old niece got hold of our Hampton Bay fan remote, we learned from her actions that holding down the button that controls the upper or lower light will, after a pause, either brighten or dim that light. Our fan is older than yours, but perhaps yours works the same way?
Apr 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
606 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
