Question about JVC GR-D370 Mini DV Digital Camcorder
Camera dead Working ok....battery fully charged....want turn on with power cord plugged in...Camera doesn't turn on...cannot reject tape door...NOTHING: HELP...Noticed the REC-off-Play button is little sloppy...Shouldn't effect rejecting tape....Any ideas before sending to repair shop...
There is a fuse blown it happens alot just make sure when you send it in that the shop is a certified jvc or a jvc only repair shop some places fix alot of different brands of cameras and sometimes you might not get it fixed right away because of the workload or not at all
Posted on Dec 31, 2007
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
I'm having difficulty putting a charge on the battery on my panasonic ag 188...the battery hasn't been used in years. Some change is happening when I charge the batt onboard the camera (plugged into the...
I had the same problem. I hope you have a battery charger. The many older batteries I have needed charging, but they wouldn't hold a charge when I tried to charge them with the battery charger. My batteries were the kind that had a memory, and I guess that the battery memories are dead. So, I saw that I had a double ended power cord that came with my camera. I took the battery out of the camera and saw a power-in hole. I just tried connecting the double ended power cord to the camera and to a power hole I found on the battery charger. It worked and gave power to the camera. It did not explode. I could not find a manual on any of the many websites. I think that the camera I bought (Panasonic Palmcorder IQ PV-IQ403) doesn't exist in the available manuals. Maybe you can find a double ended power cord and a battery charger on line or in a store.
The following information might be useful to others. The camera cassette door will not open without having the power on to the camera. The camera connects to a TV with RCA cords.
My camera power switch has 2 settings. Use the camera setting to use the camera to record and see what you are recording displayed on the TV. You must change the power switch to the VCR setting in order to play back the recording and see it on the TV. Change the switch back again to use the camera. (You can also see the playback through the viewfinder.)
My camera has a remote control which is stored in a slot. I found that the battery is in a tiny sliding door. I had to use a screwdriver to gently dislodge it from the case, my fingernail was not strong enough. The movable tab had to be pushed inward to release the catch. The coin battery was not corroded. (CR-2025)
In order to play a VHS-C tape, you must have a VHS PlayPak. The cassette door will not open unless you have a battery loaded into the cassette. When the door opens, you can insert the VHS-C tape into the opening. The VHS PlayPak holder is the same size as a regular VHS tape. It can be found on-line.
May 17, 2009 | Panasonic AG-188 Camcorder
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
JVC GR-D370 Mini DV Digital Camcorder Logo
109 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
