Question about D-Link DSL 200 (DSL-200) Modem
Modem is playing up
When i use my modem during the day it works fine but when it gets around to 8pm - 9:30pm it starts to screw up and it says no signal and than it goes into training than it starts up again then when i reconnect my dial-up it does the same thing again within 5 minutes and it is annoying if anyone could help me with this problem that would be awesome thanks =)
Your going through at a high time in the providor range, which means a lot of people are on at that time, so netowrks are usualy pretty slow. which would be the main reason why your experiencing those problems.
Posted on Feb 02, 2008
Internet connection cutting out intermitently
1. check the current firmware updates
2. verify no other devices next the the router interfering with the signal i.e. cell phones, cordless phone, microwaves, TV sets.
3. check your router or cable modem for connection during time the wireless is dropping connectivity.
Apr 25, 2010 | D-Link DIR-615 Router
I have a used ps2 system (its in good condition), i love splinter cell games, i have splinter cell pandora tomorrow. The first time i got it it worked fine, all i just needed was to hook up the internet....
more than likely you need to reset your modem.
turn off the power on your modem. unplug the power wire from your modem and unplug the coaxial wire to your
modem.
wait a minute or so and
first hook up coaxial cable to modem
then plug modem back in try it again and hopefully you will be back on line.
You just have to reset your modem connection.
This has happened to me before too.
If you have a router do the same thing.
If it does not work try the same procedure one more time.
it should work.. Good luck
leave a good rating if you appreciate my help.
Mar 27, 2010 | Sony PlayStation 2 (PS2) Console
Modem ADSL Wire ASUS resets every 1 minute
You could try to update the firmware. Also, you could check your internet speed (Google search "Internet speed test") and try to see if there is an issue either uploading/downloading, streaming.
Dec 02, 2017 | ASUS Computers & Internet
During a thunderstorm we heard a crack and believe our computer got hit - everything seems to be fine, except we cannot connect to the internet checked jacks and cords, but they are fine, could it be the...
If it's a broadband modem (cable or dsl) reboot the modem. Also look for diagnostic lights on the modem, they will give an indication if the modem is working properly. If after rebooting the modem, you are still getting trouble lights, contact the isp provider and explain your modem is no longer working. Most isp's replace faulty modems at no charge.
Jul 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
VoIP not working after modem replaced
It is possible they have your modem in an internet only class- I would call them and verify the modem is in a class avaiable for phone.
Apr 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
4100SS Power Button fails
I also had this problem with the 4100. This is what I did as a "Lo-Tech" fix. If you push in your power button and hold it in, and your modem powers on, then this should work for you. First unplug all cords. Turn the modem over and remove the small phillips screw from the bottom. Next, gently pry apart the two halves of the case. There are 4 tabs total. I found working back to front the best way. After removing the top half, gently pull the circuit board up and out. Now for the magic. Get yourself a twist-tie. Push the button all the way in, and wrap the twist tie around the whole button. Twist it down tight, and put everything back together. You should be good to go. If this doesn't work for you, or holding in the power button doesn't power up your modem, you could try just blobbing some solder over the three pins on the bottom of the board, under the switch. This should bypass the switch completely. Either way, you can cycle your power on and off with the cord instead of the button. Hope this helps!
Mar 01, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
D-Link DSL 200 (DSL-200) Modem Logo
65 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
