Question about Adobe Photoshop 7.0 for PC
No disc in drive D
My cd rom is not working. have already cleaned laser lens
  • 243 Answers
Have you tried the disc in another pc to check that the disc isnt faulty? Failing that it unfortunately sounds like you cd rom is faulty . Pretty cheap to replace now though.
Is it a laptop or desktop that you have?
Posted on Dec 29, 2007
  • Graeme Fallows Jan 07, 2008
    Please rate my answer if it helped ? Cheers!
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
My cd rom does not read dvds
you might as well check your Toshiba PC Laptop if your CD-ROM can read DVD's .. Look at this figure... ryanpajaro20_6.jpg
There will be a hint for you to check the Optical drive if it has the DVD label. Otherwise , consult Toshiba for it...
Mar 18, 2011 | Toshiba Computers & Internet
CD tray opens and shuts fine. With CD loaded and shut the screen still says NO DISK. These are disks which have always played without problem on this CD player. Is there anything I can try before taking...
When the CD player loads properly and still reads as no disk this indicates that the player lens (Optical device which reads the disk information) Is either dirty or bad. The only option you have is to get a disk lens cleaner and run it on the system. Once you run it, it is supposed to work if the lens is not spoilt. Otherwise you will just have to replace the lens by taking it to a repairer.
Hope this solution has been helpful?
Jan 17, 2011 | Audio Players & Recorders
Cd rom drive reads some cd's and not others
If those other discs are working in other cdrom drives then you could have a dirty cdrom drive, a laser failure, or it could be a firmware problem in that drive. Check the mfr's website for any firmware updates first. If that should fail, then you will need to replace the drive.
What's happening inside is, you have a laser inside that bounces a beam off the disc and receives the beam into a buffer. The beam scans for and detects "Pits" and "plateaus" on the surface of the disc (it's kinda like morse code on a plastic disc.) and the dots and dashes reflect into the buffer.
If you cannot read a disc, that means the laser is having trouble with either:
1. emitting the beam,
2. targeting the tracks where the pits and plateaus are or
3. receiving the beam into its buffer
SOMETIMES a burned disc is harder to read by a standard reader, but not often. Most times it is a sign of dirt on the buffer receiver, dirt on the lens, or inability to scan the tracks. Try using a cdrom lens cleaner, and update the drive firmware. if that doesnt help you, you need a new drive.
May 17, 2010 | Dell (6T980-A01) CD-ROM Drive
My CD burner has stopped working. I get a message that a disc needs to be inserted when one is already there.If I take it out and put it in again. (These are new discs.) I receive the same message. I refer...
Use a cd-lens cleaner for first step u will get this in computer shop.
u have wet and dry method choose one
if u are used to remove the cd-rom drive unscrew the cd-rom drive open it and clean the lens with a dampt cotton cloth then with a dry cotton cloth
Nov 12, 2009 | Computers & Internet
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
It keeps saying there is no disk in the console or it will say system error
1) Lens is dirty
2) Game(s) disc scratched
3)cd/dvd rom broke
4) systems mainboard is broke
(stop if it works after each)
First try a can of air, or a straw and strong lungs to try and clean the dust from the top of the lens of the laser.Then try another game. Then take apart the system, and clean the lens with a q-tip and rubbing alcohol. Replace cd/dvd rom drive, ask google for directions.
Dec 01, 2008 | Video Game Consoles & Games
Benq CDRW 5232X drive, running on Win XP.
The laser lens in your drive might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Adobe Photoshop 7.0 for PC Logo
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
