Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42WH36P rear projection TV has wavy lines
I have been experiencing problems with my Toshiba rear projection TV, which started around two weeks ago and has gotten worse. When I switch on the TV, there are wavy, jagged horizontal lines across the screen. I have had a look at my arial, set top box, cables etc to see if it was any of those causing the problem. Switching the tv off and on again makes the picture appear a little bit clearer, but it's still no way near watchable. I am hoping that it is not the TV as I have only had it for 4 Years! I would like to know if it sounds like a typical description of a problem found with Toshiba rear projection TVs (if there ever is one!)
  • harrisro Jan 16, 2008
    My 42H83 started with minimal picture scramble that would clear up over a period of about 30 minutes and has progressed to full screen scramble that won't go away for about an hour and even there there are episodic flickers in the picture. Don't know what to do about it, not warrantied and the tv is 4 years old, however it has only been in use for about 2 of those years. I don't want the run around from a repair service either. Anyone have this issue resolved and what was the solution? Mind you, I am female so keep the jargon simple please. The tv is too heavy to move by myself as it is placed in a built in about 3 feet off the floor.
  • Nickoli_p Feb 18, 2009
    Hi i have the above tv and the image is all jittery..but when u switch the teletext on or the menu's they appear fine..i also tried plugging a laptop into the component ports but its just the same.
    Anyone know what the problem is? im very good at soldering and would try to repair it if i knew what was the bad component..
  • 301 Answers
The problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Posted on Feb 22, 2008
    Problem Solver:
  • 10 Answers
Remove the front grill and then the acess pannel to the guns . you will find 6 knobs 3 for color and 3 for focus dont touch the focus the 3 knobs you want are pots for color voltage r g b red green and blue turn the problem color to the left and if need b the others also. a little goes a long waw
Posted on Aug 19, 2009
  • 4,402 Answers
Convergence amp ic bad
Or send to
Posted on Feb 21, 2008
Lines on my toshiba model 46h84 projection tv has lines on screen until it warms up What could be causing thi. Once it warms up the picture is fine. which takes about 10 minutes
I have the same issue with mine which started a couple of months ago and has only gotten worse. I've been googling this and found that it could be the convergence module(s), apparently there are 1-3 of them and ALL of them should be replaced. I'm not sure on a cost, but I'm guessing it won't be cheap. I think we are just going to get a new tv, with the prices for LCD's coming down this will probably be a cheaper option. Good Luck :)
Mar 23, 2010 | Toshiba 46H84 46" Rear Projection...
Toshiba 42" projection tv model number 42WH36P rippled effect on picture
Well this could be a serious issue you may have to call to a tech guy
good luck
Dec 18, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
42wh36p - wavy lines
can you post a pic of the screen? Its hard to diagnose that type of problem with out seeing as it could be a deflection or a signal issue.
Apr 05, 2008 | Televison & Video
Toshiba 65hdx82
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Nov 25, 2007 | Toshiba 65HDX82 65" Rear Projection...
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 50h13 projection tv
You have a bad hyper board part #23148024.  The part is NLA.  I have one in stock or you can have yours rebuilt at PTS Electronics 800-844-7871.
Oct 02, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
1,519 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
