well it sounds like you knocked a rod loose that connects to the door latch. now you would have to take off door panel and fix this issue from the inside good luck.
THERE IS A CLIP ON THE INSIDE OF THE DOOR ON METAL ROD THAT GOES TO THE LOCK MAKE SURE ITS NOT DAMAGE OR FALLEN OF WHERE THE ROD GOES TO THE LOCK THERE ARE 2 ROD ONE OPENS THE DOOR THE OTHER ONE LOCKS THE DOOR
Chances are the autolock doesn't work because it "sees" a door open. Check the plunger between the door and the frame of each door to see if the plunger is broken, bent, or otherwise not working.
This is something that happens to me on the same car - if you use the fob to unlock the door, ti will lock automatically in about 20 seconds if you do not pull an outside handle to open the door - it is part of the security system - I have not found a solution other than one similar to yours - a "dumb" key in my wallet to unlock the door when it happens
On the inside trim, you can remove screws that are by the door handle,
arm rest, under door and side of door and then gently pull back on the
panel as there will also be retaining clips attached and you don't want
to break them. You'll need to lift the door panel upwards in order to
get it off the window ledge. Then you'll need to manipulate the panel
and disconnect the door handle linkage from the door handle and
disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
I have a 2004 honda pilot.The passinger door and the back door behind the driver seat will not lock or unlock with remote or with door lock switch,What can I do to fix it?
It did for the ist 4 1/2 years I owned the vehicle!!
