Question about Dryers
DRYER I HAVE MAYTAG PERFORMA DRYER MODEL PYE2000AYW DOESN'T RUN NOT AT ALL
  • Gearsofwar Jan 10, 2008
    I have a Maytag Performa dryer model PDET910AYW. It doesn't start at all. Checked the door switch jumpered it but still it does not start.
  • Shinecatcher Jan 04, 2009
    I have the same problem with my Maytag Performa Pye2000ayw. I unclogged the vent (yes, it appeared clogged). Taped the 2 wires to the thermal switch together (above the element), and plugged it back in. Still doesn't work. Checked online for more help, but not sure what's next. If the thermal fuse is blown, will taping the two wires together really turn it on? The wires are pinched together with a flat ending so they don't really interconnect--just taped them flat together. The dryer has not been performing well for over a year--dry cycle is about 1 hour. Never overheated. My husband said the last time he dried clothes it took even longer to dry. I don't know if the heat was on or not. Will the element stop the dryer from turning on, too?
    Sergeant:
    Champion:
  • 262 Answers
The door switch is a good start but UNPLUG DRYER and under the top of the dryer is a thermal limit switch lift the top using a putty knife on each side of the lid raise it and on the left rear you will see the element look under the wires going to the element (straight down) you will see a limit switch with two wires on it remove these wires and plug them into each other.make sure they dont hit the frame and plug dryer back in and try to start it if it starts replace the thermal fuse you can tape these wires together with electrical tape and use it until you get the fuse but dont wait 6 months to do so it could cause a fire .Good Luck
Posted on Dec 31, 2007
  • 164 Answers
You're not giving me much to work with. so for starters check the door switch
Posted on Dec 30, 2007
2 Suggested Answers
Oceti
  • 51 Answers
SOURCE: DRYER
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
Posted on Jan 10, 2008
My Maytag Performa won't run at all
I looked up your model. The blower wheel on these 31001317
causes the dryer to over heat. The fuse kit LA-1053 mounts here:e930c75.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Dryer thermofuse blown again
Probably restricted air flow caused by lint build up. Clean out dryer and all vent pipes, check damper outside and see if it opens. After you clean out everything run dryer on aif fluff/no heat cycle and see if there is good air flow outside. If it is electric it could be that the heating element is burned out and shorting out against the frame. This can cause overheating.
May 12, 2008 | Dryers
DRYER
Jan 10, 2008 | Dryers
Dryers Logo
499 people viewed this question
Top Dryers Experts
Marvin
Marvin
