Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa c250 /where is it at in my computer
Usb is plugged in and icon is at the bottom in tool bar but cant find in my computeer mode so that i can drag and drop music file in it
  • darrell43 Dec 29, 2007
    if you dont have a solution can you give me the 1-800 help#
  • clarkietie
    clarkietie Dec 30, 2007
    My Computer does not recognized my sansa c250 2GB mp3?
    Problem Solver:
  • 44 Answers
Windows media player is the place you should find it.
Posted on May 22, 2008
I dont know how to charge my mp3 player and its dead
Plug one end of the supplied cable into the slot in the bottom of the Sansa. Plug the other end into a USB port of a computer. Make sure the computer is turned on, and it should start charging.
Mar 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
I had music on my sansa cant find it and now it said memeroy is full and i know it not
hi its because of virus in ur system so try 2 formate ur card for better result else install anti virus in ur system
Aug 24, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 - How can I change from MSC mode to MTP mode?
From the Sansa c250’s Main Menu, go to Settings/USB/Auto Detect
or MSC to change the mode. Auto Detect settings will default to MTP mode.
Jul 24, 2009 | SanDisk Sansa e260 MP3 Player
USB not getting recognized
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
When i open the sansa c250 i get an icon that says FIXED SD
The computer is registering that an SD card is inserted into the Sansa. You probably will have to switch the USB Mode or remove the SD card. Here is a link to the user manual that explains this - very helpful:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Safely disconnecting Sansa C250 from Laptop with Vista
Right click the taskbar and select Properties. Then select Customize - look in past items and see if you find the safely remove hardware option.
-Tha Mp3 Doctor
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa C250 not recognised
The Sansa C250 doesn't have a setting on the player to put it into USB, or MSC mode.
By default, it's always in MTP mode (Microsofts slow and crappy DRM enabled protocol).
You can force the player to connect to your computer by doing these 3 things:
1. Ensure that your player is OFF.
2. Set the Hold slider to LOCKed.
3. While holdind the "<<", (LEFT or Previous) button down, connect the c250 to your computer via the USB cord.
You should now see 2 new drives in your "My Computer" window. One drive is the c250's internal memory, and the other is it's microSD slot.
Feb 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa C250
Go to your device menu and click on the usb mode....make sure it says MTP mode or auto...if that doesnt solve the problem...do a firmware upgrade for the device...
Oct 28, 2007 | SanDisk Sansa c150 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
