Question about Sony (DDU1613) (ddu1613black) Internal DVD Drive
Dvd rom tray opens so theres power, but doesn't show and has error 19 on pc
  • 1 more comment
  • voyager1 Dec 29, 2007
    Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
  • voyager1 Dec 31, 2007
    when you say resaet it the drive , as i'm not a tech buff what does thus actully mean.
  • Anonymous Dec 30, 2008
    drive test show unit is fine,windows xp home loads drivers after i uninstall it & then I get error code 19, something wrong in registery, also found where it shows cannot load vxd,i assume is the driver.
  • 56 Answers
Try these steps:
1.Go to Start>Run and type regedit.Than go to HKEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>{4D36E965-E325-11CE-BFC1-08002BE10318} and remove the upper and lower filter.
2.Go to start and right click on my computer and than click on manage.On this creen go to the option which says Device manager and look for the option for the cd drive.Expand it and than right click on the option it gives you and uninstall it.After that close everything and restart the system.
3.Also similar way you can remove the primery and secondry channels in the device manager.
4.Also you could try reseating the drive
Posted on Dec 29, 2007
  • Anuj Sharma
    Anuj Sharma Jan 01, 2008
    I mean teake out the drive from the system and put it back in.
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Xbox code 416b-0000-3080-0504-8007-0070
If you have personally, or had someone else, modify the firmware on your console's DVD-ROM drive to play burnt games, you will need to restore the drive to its stock firmware and then finish the update through that. You can then reflash the DVD-ROM as desired to play any new games you wish.
If you have not modified your Xbox 360's DVD-ROM drive, then it is likely that your console either has a DVD-ROM that is failing, or it is simply having trouble putting the DVD-ROM into flash-ready mode to accept the update. To attempt to fix this error, eject the DVD-ROM tray and then pull the power cord out of the console, thus preventing it from automatically injecting the tray. Next, push the tray in about half way, with about a finger's width of room between the console's shell, and the apex of the curve in the hollow center of the DVD-ROM tray. Then, plug in the console and power it up while holding the tray in that position to prevent the console from injecting it automatically. Expect resistance, but it will eventually give up trying to move the tray. From there, you can release the tray and allow it to update as usual. Do not inject the tray by hand, let the console reset the tray on its own after it finishes updating. That should fix your problem if that was the specific problem causing the error. Either way, good luck, and I hope your error is resolved.
Apr 17, 2014 | Microsoft Xbox 360 Console
My Cd/DVD burner has disappeared I have tried deleting the upper and lower filters and it still doesn't show up the tray opens the light comes on but it's not usable or found anywhere I have an HP...
Try this:
I have to ask, after deleting the upper & lower filters did you reboot the PC?
If so try this:
Go to:
Start>(right click on Computer)left click on Manage.
Left click on Device Manager
Locate your DVD/CD-Rom drives.
Right Click on the DVD/CD Rom-drive> uninstall Now reboot the PC.
If the drive does not come back in Computer> devices with removeable storage go back to Device Manager (Start>right click computer>Device Manager) to see if you can see DVD/CD Rom-drive.If you dont see the drive in this location then it sounds as if your DVD/CDRom-drive is no longer working and you will have to replace it.
Aug 09, 2012 | Computers & Internet
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
Dvds wont play in dvd rom on travel mate 2480
if the icon of DVD is there but when u try to open it doesnt bring any windows gives u error unable to read the contents then ur DVD drive lens is faulty try cleaning it with a very soft cloth open ur drive tray and u will a crystal eye shiny thing just clean it by rubbing very gently with a tissue paper or very soft cloth which is used to clean lcd's or if u have a lens cleaner cd it will be best , if it doesnt work then i will suggest changing the DVD ROM drive there are plenty of cheap DVD writer drives available on ebay under 60 $ or so try them pls vote if u find me helping
Feb 23, 2009 | Acer TravelMate 2480 Notebook
Will not recognize dvd rom
Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
What are your computers specs?
Jan 02, 2009 | Dell Dimension 2400 PC Desktop
Cd/dvd rom
I am presuming that you have the correct driver for the DVD, and nothing else has changed (no new DVD software that might cause this problem by addressing the drive improperly). Nero and Power DVD can both cause problems if your DVD is newer than the software version.
Now, all that out of the way, here is the diagnosis. DVDs are much higher density than regular CDRoms. DVDs average 4.5 gb, whereas a CD is caped at 0.7gb (700mb). Thus, DVD drives have very low tolerance for ANY kind of error. Therefore, DVD combo drives are not likely to last as long as the rest of the laptop's hardware. Shock at relatively minor levels can damage a DVD drive. Often, they will still open a regualr CD, but fail to read a DVD directory. Your error code, if it is posted at startup, indicates the drive is malfunctioning. You can test it easily. Usually there is only one screw that holds it in (underneath the laptop, about 4 inches from DVD tray cover, towards the center). Turn off laptop, flip it over on a towel, and remove that screw. Tuurn the laptop over again, then insert a straigtened paper clip into the small hole in the DVD tray face. Be careful to push lightly and STRAIGHT in with this paper clip and the tray will pop open. Pull gently, and the whole DVD body will slide out. With a new or used replacement DVD or CD, reattach any hardware on your old DVD to the new one, then slide it back into the laptop 9no need to install screw just yet) Start laptop. If error is gone and DVD plays OK, insert the screw again and make your old tray cover fit the new drive (always can be done if you look closely to find the tabs and remove it gently). Sometimes some plastic will need to be trimmed with an eExacto knife to get a good fit.
Feb 16, 2008 | Toshiba Satellite A60 Notebook
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
How to instal a laptop dvd rw
open cd rom laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Sony (DDU1613) (ddu1613black) Internal DVD Drive Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
