Question about Sony PlayStation 2 (PS2) Console
Playstation 3 wont start on a scart connector
Playstation 3 has worked on HDMI TV. Am on holiday and am using the standard supplied scart connector. Have tried it on two TVs but get nothing.
    Problem Solver:
  • 9 Answers
Did u check the right plug? if so, check it again. Maybe u forgot to plug other one!
Posted on Jan 01, 2008
I have sound but no picture please help
Make sure that your cables are fully plugged in and pushed into both your PS3 and your PS3. If you are using a standard scart lead, make sure that all 3 connectors are fully pushed in and are intact.
If you are using a HDMI cable, just make sure it's pushed in fully on both ends. If it still does not work, trying getting a new HDMI cable or scart lead, as they may be damaged in some way.
Oct 14, 2011 | Sony Playstation 3 (PS3) Console
I can not see any picture or sound at all. We have the HDMI cable pluged in the PS3 and the TV, but red white ,and yellow plugs we r not sure where they should be.
There are different settings for PS3 video output, i.e. if it is set for HDMI it wont display when a scart lead is used. Try the scart connector, if it works go into settings and change to how you want it set, dont forget to save settings
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
The PS3 switches on, lights up, drive and disc drive working but No Signal on TV. Saw HDMI cable solution previously posted. Does that work for SCART also?
yes just change hdmi for the word scart
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my playstation three it goes to a black screen
If you used it recently for HDMI and have gone back to using standard definition the system wont automatically switch over.
If this is the case you will need to reconnect it with a HD TV and switch it to scart (or whatever you usually use) under the display options then quickly switch your TV to the correct channel and click yes when it asks if you want to keep these settings.
Bear in mind that when you do this you will need both the HD AND the scart plugged in at the same time.
Hope this helps!
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
I jus reseted my playstation 3 and still didnt work, i get sound but no video. my standard a/v cables do not work, but the universal a/v cables come in black and white
What cable are you using, HDMI or SCART?
Try to use another cable, a cable of friends ps3 or so.
It's best to use HDMI if your tv set has sockets for it.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Playstation doesnt display at all
hold the power button until it blink twice then turn off.
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
