Question about Kenmore 73952 Gas Dryer
Dryer is leaving brown streaks on cotton clothes
Not sure why - we tried various heat settings but the dryer is leaving brown streaks - almost like heat marks on some clothes.
Any thoughts?
  • 2 more comments
  • DewItYerself Dec 31, 2007
    I have a kenmore electric dryer model 417.80142000 with exactly the same problem. We have been finding small brown streaks on fabrics that resemble burn marks that cannot be removed with spot treatment. Yesterday our new $200 sheets came back ruined. We get these marks on long cycles and short cycles, high heat and low heat. The vent appears to be unobstructed.
  • stumped14609 Jan 15, 2008
    We have the same problem with our seven year old Kenmore Model 417.801420000 Dryer leaving brown or burn marks on clothes.
  • Anonymous Jan 02, 2009
    I also have a Kenmore heavy duty that leaves brown marks that look like burns from a steam iron ~ like brown with a small brown hole pattern in it. Sometimes it's just spots.
  • Anonymous Mar 31, 2014
    samsung dryer leaves marks on clothes, why?
    Sniper:
  • 88 Answers
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Posted on Jan 17, 2008
Brown streaks on white cloths?
Hi Ralph,
It may be important to have an idea as to what caused the stain/discoloration. Carbona (http://www.carbona.com/home.php) has different products specific to the various reasons for the problem. You may be able to use bleach, depending on the fabric affected. Some white material turn yellow with bleach
Hope this helps ~ Good luck!
Alexander
Mar 02, 2015 | Kenmore 45081 Front Load Washer / Dryer
My dryer is leaving brown stains on my clothes. I think that the drum needs to be aligned. Is this an easy task?
If your dryer is leaving small brown streaks on your clothes, then your drum seals need to be replaced. It is not a hard task if you know what youre doing. It is a complicated one for a beginner because you have to take your whole dryer apart to replace the seals
Jul 13, 2011 | Dryers
Brown streaks on laundry. possible loose drum?
It may be correct. This may also be caused by oil leaking from the washer machine. Perhaps the heat is burning the clothes leaving the streaks.
The common cause of this issue are oil leaks.
Dec 27, 2010 | Frigidaire FGQ332ES Gas Dryer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Aug 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Kenmore 73952 Gas Dryer Logo
1,457 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
