Best Solution
posted on Oct 26, 2009
Rank: Guru
Expert
Rating: 94%, 7478 votes
hello sir, engine will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, check oil sensor , now for the carb, empty fuel tank, ,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut on. good to go,hope this helps, mr fix it, oh could you please rate this solution,thank you$$$
