Question about CyberDrive DVD-ROM DM-166D Internal DVD Drive
Drivers for cyberdrive dm 166d dvd
Where can i find drivers for my cyberdrive dm 166d dvd
Have you tried www.drivers.co,? How about restoring your system back to a previous day and time before your problem began?
Posted on Jan 09, 2008
  • Laura Rozamus
    Laura Rozamus Jan 09, 2008
    I meant to type.com!
CW099D CD-RW cd tray keeps opening and shutting
check the leads that attach your cd-rw make sure connections are secure
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps you
Sep 13, 2011 | CyberDrive CW099D CD-RW Burner
Controlers of cd522d Please cd522d controlador
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 12, 2011 | CyberDrive CD522D Internal 52x CD-ROM...
Will not print and will not read?
make sure that the cd-rw burner is getting enough power test all leads that are attached to the cd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 07, 2010 | CyberDrive CW088D CD-RW Burner
Is there anywhere I can find a replacement drive
Yes... this is an OLD cd burner.
You can get a replacement DVD/CD burner for about £12 to £15.
Just look on sites like Amazon, search for an ide dvd burner.
You do NOT want a SATA drive
Aug 30, 2010 | CyberDrive CW038D CD-RW Burner
CW088D CD-RW Tray ejects with CD in it but not empty
If the tray retracts but doesn't close 100% then it will open back-up. If it is closing fully then returning open then it is a bad drawer switch. It's hard to get to but if you do get in there, a little WD40 lube might help it actuate. Good luck!
Mar 15, 2010 | CyberDrive CW088D CD-RW Burner
DX082D Cyberdrive burner will read a cd and dvd but doesnt seem to want to burn a dvd-r...any ideas? you dont have the exact burner im using on your list its actualy the DX082D Cyberdrive burner thanks
you have to see it you if your drive will burn dvds or cds but it should try changing the dvd you are using +r not -r and look at updating the driver it should correct the problem hope this was helpful:)
Nov 16, 2009 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
http://www.opendrivers.com/category/15/cd-rom-free-driver-download.html
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
Need Cyberdrive / khypermedia dvd cdx082d xp drivers
I think it may be the dm168d driver, but I cannot be sure from the info.
http://www.cdrom-drivers.com/drivers/126/126445.htm
Also found a guy at the following link who has one or a very similar one.
http://club.cdfreaks.com/f84/tell-us-about-your-system-86875/
ccbadd CD Freaks Senior Member
Join Date: Dec 2003 Location: Texas Posts: 303 Here my PC:
Dell 4600
P4 2.4 /800fsb /HT
768MB PC3200
Hitachi 160GB 7200rpm SATA drive
Nvidia FX 5200 128MB agp video
Dell Ultrasharp 1800FP monitor
Aopen 16X dvd-rom Primary Master
BTC 1004IM DVD+-RW Secondary Master
CompUSA brand PCI Firewire card
Haupauge WinTV PCI card
Cyberdrive 082D *X DVD+RW in external firewire/usb combo enclosure
I also have a Pioneer 105 and Nec 1300A that are in externalenclosures, but I tend to stick with the Cyberdrive right now. The BTCwrite some media fine (ProdiscS03) and others not so good (Rytek G03and G04) so I primarily use it to read tough disks as that is all Iconsider it really reliable at.
Its a shot in the dark, so please don't vote unless I FIXYA!
thanks!
Jan 02, 2009 | Computers & Internet
CyberDrive DVD-ROM DM-166D Internal DVD Drive Logo
59 people viewed this question
Top CyberDrive Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a CyberDrive Computer and Internet Expert? Answer questions, earn points and help others
