GE DVLR223 Dryers
Problem for GE DVLR223 Dryers
How do I replace the felt seal on a DVL223 clothes
By clshaw3 on Oct 19, 2009
How do I replace the felt seal on a DVL223 clothes dryer?
Solution #1
posted on Oct 19, 2009
Not Rated)
lylerwh
Rank: Wiz
Rating: 85%, 73 votes
There are usually some torxes screws underneath the top of the dryer. They need to be removed. Then there are a couple of bolts at the bottom, they normally don't have to be taken all the way out, just loosened. and there should be a couple of bolts inside for the front assemble...unplug the door switch, lift up on the door and just move it aside. Don't move the drum around too much since it shouldn't have to be removed...the felt is normally attached to the door is should be replaced the same way you remove the old one. A good time to look at the wear on your slippers, which are really plastic glides for the dum to run smoothly on, but they are right there, and if they need replaced, the job would be simple at this point and cheap.
Was this helpful?
Yes
No
Popular Solutions for GE DVLR223 Dryers
Questions and Unsolved Problems for GE DVLR223 Dryers
Do you recommend GE DVLR223 Dryers?
Answer
Answer
The dryer stopped working in the middle of drying a load of clothes.It won`t start at all now.If I... (More)
Answer
cuts off,everything but timer
Answer
The belt is squeaking and I am not sure how to access it?
Answer
Dryer Does Not Turn On. Worked before, but does not now. Turned the on/ off knob and nothing... (More)
Answer
my dryer makes noise when it works, and also some of the slections won't work as well.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE DVLR223 Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
