Tranfer case on 1998 chevy k1500 4x4
I changed out tranfer cases and know the lites on my dash buttons dont lite up i have checked the fuses all our good , i unhooked the battery for a few minutes and nothing changed could you please help me
  • handyman862 Dec 29, 2007
    how will i now when i will be getting a answer to my question
  • 52 Answers
Handyman862, Transfer case is an integral parts of ur transmission for your front wheel drive. Purely mechanical with few wires connecting interlock switches that is mechanically actuated to indicate if you are on 4 or 2. Must have forgotten to reconnect or not properly connected. Please recheck d wiring again.
Posted on Dec 30, 2007
Tail lite is out put new lite and still dont work casing was filled with waterother lite is working
not fuses as both lights use the same fuse
if it was filled with water, probably a corroded contact or wire corroded of the holder
Aug 17, 2016 | Cars & Trucks
Transfer Case stuck in 4 wheel drive
To Troubleshoot Transfercase stuck in 4wd issue.Click the link below and follow the details:
http://www.allcarhelp.com/2015/04/transfer-case-stuck-in-4-wheel-drive.html
This will help.
Thanks.
Apr 14, 2015 | 2000 Chevrolet Silverado 1500
My 1988 chevy silverado's dash lights and radio dont work.fuses are good.someone told me to check the fuseable links. is that possible and where are they?
Did you check for voltage at the fuse circuits? Use a test lite. Your dash lites may go hot from the headlamp switch. Radios on some makes and models have two voltage circuits, one circuit is for memory, hot all the time, separate circuit to operate the radio, itself, goes hot with the key on. I haven't looked at your wiring?
Jan 17, 2015 | Chevrolet Silverado 1500 Cars & Trucks
Stuck in 4x4 low switch on dash 1998
It is your 4 x 4 electronic shifter at fault. Located on your transfer case it is mostly black/brown plastic electronic switch that engages and disengages your transfer case from low, high 4 x 4 or 2 wheel drive.
Check connections for electric continuity and replace it if there is no power...
Feb 25, 2014 | 1998 Ford F150 Regular Cab
How to reset the lite on dash board " change engine oil" on a automatic 2002 chevy avalanche Z66?
Different car has different way to reset. Read its manual, it should tell how to reset.
mai
Feb 25, 2013 | Cars & Trucks
When i select 2 wheel drive, the lite flashes and ..... the light on auto comes on...is the 2 wd working
is this a blazer or simular the motor on transfer case burns out and is exspensive to replace you can get a cheaper one from autoparts but before all this check all fuses i mean all i think you have 1 or 2 in engine compartment which are marked 4x4 or tranfer shift something like that and another inside truck as well you have a relay outside that you can check sometimes you can play with it enough to shift it back to 2wd because its a safty feature so that it shouldnt get stuck in 4x4 but sometimes it does and its hard to drive on dry pavement as well when you do change tranfer case module it has to be in proper position or else you can damage the unit if not positioned proper so check before engaging after replacing unit
Jan 06, 2011 | GMC Envoy Cars & Trucks
Where is the fuse for the lighter in a 1998 Chevy Cavalier?
in the fuse box its probably aslo your interior lite fuse box is under dash near foot pedals look up
Aug 21, 2010 | 1998 Chevrolet Cavalier
Flashing Dash Board Lites
TELL YOUR MECHANIC TO CHECK THE RELAYS IN THE B.C.M. AND THE FUSES AS WELL. TO RESET SOME SYSTEMS YOU MUST USE THE KEY ON THE DRIVERS' DOOR WHILE PRESSING THE ALARM BUTTON ON THE REMOTE. GOOD LUCK
May 03, 2009 | 1998 Plymouth Voyager
84 Vette car sits for three days and it drains battery battery is new----just had alt. rebuilt-- short where?
If it still does it, locate the fuse panel and with the car off, pull a fuse and measure the current draw.  Be careful.  Make sure your meter is on HI AMPS.
Aug 13, 2008 | 1993 Chevrolet Corvette
Computers & Internet Logo
97 people viewed this question
Alun Cox
David Payne
David Payne
