Question about Sansui Televison & Video
Cannot mount sansui LCD
Hey, I recently bought a new lcd of "sansui japan", model no' LCT32SD
I believe that I got the old series (before HD*** series) .
Now, my problem is that I can't mount it to the wall, I got mount adapter, and an arm, and I just got no holes in the back of the tv for any of them.
So, I really need to know how to mount it
Here's the product official link: http://www.sansui-global.com/english/products_detail.php?cat=LCD&cat_id=&ss_model_no=LCT32SD
Thanks alot!
Highdefjeff
  • 124 Answers
SOURCE: 42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Posted on Apr 08, 2008
jerryg50
  • 1689 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
SOURCE: web site for registering
please i bought 22'' samsung lcd . When i tried it the first time the standby mode could not go away, so i cannot enjoy the machine. Please help.Bye Paul
Posted on Oct 31, 2008
  • 118 Answers
SOURCE: Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Posted on Nov 18, 2008
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
Desktop off of the screen
That might be the possible resolution the TV can recevie. Nothing more can be done.
May 20, 2013 | Sansui 19 in. LCD TV
Hello, I recently had a little accident with my TOSHIBA 40A8000 LCD TV. It dropped about 3ft., and of course the LCD display is rocked. I'm wondering if any replacement is sufficient, or if its...
You need to get the model number as printed on the LCD panel so you can match it exactly since you will have to transfer the T-CON and and the backlights inverter board to a new panel, all the mounting holes and dimensions of the panel will have to match the old one otherwise it will not into the chassis. Make sure to get the version number of the screen also, same model can have more than one version.
40" panel can be $200 and up for used not-perfect condition.
You will be better off selling the boards on EBAY.
You look or contact these people:
https://www.myallparts.com
http://www.retechtv.com
www.interliquidparts.com
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 29, 2011 | Toshiba 40XV645U 40 in. LCD HDTV
Picture quality is too bad in NEW sansui 32" LCD
As it is new, take it back for replacement. If you bought in online, have it replaced as it may have been damaged in transit.
Don't bother to try and repair it, it is not right.
Hope that helps.
Nov 27, 2010 | Sansui HDLCD3210 32 in. LCD TV
Activating HD mode
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
Dec 09, 2009 | Sansui HDLCD1908 19 in. LCD TV
How to program a Sansui model #HD LCD 2200 for digital tv. I no longer have cable and have misplaced the user's manual.
HI,
this is the manual and you need the cable tp program it...you can get it easily at a affordable cost
http://tv.manualsonline.com/ex/thread/view/idThread/2442932
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Sansui HDLCD-2200 22 in. LCD TV
SANSUI HD LCD 42 INCHES screen is broken and needs replacement ,
You're better off just replacing the TV because of cost. If it is still under warranty why not contact the dealer you bought it from for an authorized service center location.
Aug 12, 2009 | Sansui HDLCD-4212 LCD TV
No sound when Wii is switched on
DID YOU TRY PLUGGING YOUR COMPONENT CABLE INTO A SCART ADAPTOR FOR YOUR TV...THIS SHOULD FIX IT FOR YOU.... I TAKE IT YOUR TV IS A 5 SERIES OR A 6 SERIES SAMSUNG.. GREAT TVS HAVE ONE MYSELF, BETTER WHEN MORE CHANNELS ARE BROADCAST ON FULL HD BUT...
Jan 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My sansui 19 in lcd tv is not receiving signal from my dell compu
check the cable,check the graphics adapter is seated in ur system perfectly,check if any boot sirens came from ur cpu when starting the system.
Jan 04, 2009 | Sansui 19 in. LCD TV
Televison & Video Logo
63 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
