Question about Canon PIXMA iP90 Mobile Printer
Color ink senser will not ingage
My color ink cartage senser will not ingage, thus the printer will not print. I have taken the cartage out and replaced it several times. I have inspected the senser, it seems to be intake, it folds with a hitch, and appears undamaged. I have had the printer for 3 years without a problem tell now.
Purvis
  • 2 more comments
  • Anonymous Feb 14, 2008
    black ink will not print. changed cartidge several times. HELP!!!!!
  • Anonymous Mar 07, 2008
    Mine is giving me no error message. It says nothing about the sensor. It prints color with no problems. It goes through the motions of printing black and white, but nothing appears on the paper. I have done the deep clean function on the printer for the printing jets with no resolution to the problem.
  • selfstarter Apr 16, 2008
    same problem as the original poster. (NOTE - the two other posters are not having the same problem).
    the error message is:
    "The following ink tank is not installed:
    Color Ink Tank
    Install the ink tank properly and close the printer's cover. If you do not want to install the ink tank, click Cancel."
    i took a pocket knife and wiggled the sensor around and got it to work one time. then i didn't use printer for a month, and the next time i went to print it gave the same message.
    it's *possible* that ink is getting down into the sensor and drying and causing something to stick... will try cleaning it, but... this is a super annoying problem.
    any ideas how to take apart the print head and maybe look at the connection(s) to this sensor?
  • Anonymous Apr 17, 2008
    The new colour ink tank with correct number has been installed in the printer canon pixma ip 90 but the problem mentioned below persists and no print out.
    Color Ink Tank
    What to do? plz. help!
    Sergeant:
  • 390 Answers
What was telling you it was the sensor, did the printer give you an error message. Is this a standalone unit or hooked to a pc?
Posted on Feb 11, 2008
Why can't I insert ink cartage in slot?
please open the door of printer and push the cartridge slowly and then the cartridge push down, the cartridge come out.repeat this same process to insert new ink cartridge.
Oct 01, 2015 | HP Deskjet 2540 Inkjet Multifunction...
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Epson nx105 has new black cartridge but cyan out. we just want to print black ink but it will not print at all b/c one is low. any suggestions?
you can change the setting in the printer prefaces or do what i did keep an empty color cartage in the color slot and a good black cartage in its slot.
Dec 29, 2009 | Epson Stylus NX105 All-In-One Printer
I HAVE MX 300 PRINTER IN WHICH THE COLOUR CARTRIDGE FINSHES OFF QUICKLY THOUGH I DO NOT USE COLOUR PRINTING PLEASE ADVISE
You can goto printer settings and choose black and white printing only, it will be there in one of the options of your printer.If your printer has only one cartage Color, then when you rpint in black and white you are using all 3 colors to create this black and white, nothing much you can do there. But if your printer has two cartages 1 black&white, and 1 color then tell it in settings to print only black and white, hope this helps
Nov 29, 2009 | Canon MX300 Office All-In-One Printer
Won't print color. Color inks are full, cleaned jets, but still won't print in color.Black ink prints.
Due to not used your cartage the opening of the cartage lid become freeze so put it for some time below running water and then try to print it will work
Nov 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Spotty color print
first of all you can remove your color cartage
and check this cartage to simple page
which color is appers
after that refill the cartage from the serge
3ml
3 color in the cartage and every color every point you can refil
Sep 20, 2009 | Alps MD 1000 Thermal Printer
My printer is printing yellow only
hi, i think the other ink is finished in your printer cartage. i also have the same problem and then i buy a ink refil kit and then fill the cartage with blue and mergenta colour and then it working fine. I suggest while filling the cartage please don't remove the slip, just fill it using injection.
Sep 04, 2009 | HP Color LaserJet 2600n Printer
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
I cant print in color
If your trying to only print form a tri-color in cartage and you dont have a black cartage in the 2nd slot as well you might try doing the following
I am not sure whether u can print only using one cartridge(color) with this All-in-One. Check out the following steps nd let me know if they have helped.
1. Remove the Black cartridge from the All-in-One.
2. Open HP Director.
3. Click Settings -->> Print Settings --->> Printer Toolbox.
4. Under the Configuration tab, select One Color cartridge from the drop down list and click apply.
Now,try printing.
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I need an alignment page!
open the color properties in printer properties, then set the color ratio as u need ,then start printing.
Aug 16, 2008 | HP PSC 1350 All-In-One Thermal Printer
Canon PIXMA iP90 Mobile Printer Logo
88 people viewed this question
old marine
old marine
