Question about Reddy R155D Utility Heater
Igniter will not light
My heater ran out of fuel and now the fan runs but the glow plug will not light. i found i fuse and it is ok, is there another? or is there a reset, i do not see one? thanks, dan federico
There might be a small push button reset somewhere in the mid section
Posted on Dec 30, 2007
Heater would not start this morning It tried for a second and then just would not ignite. it was running fine yesterday
Take the top cover off of the unit. Plug it in and look at the ignitor for a bright glow or spark, depending on your ignition source. This should happen before the fan starts. Once the fan starts you should be able to see fuel spraying out of the spray nozzle. If there is no fuel, check the fuel screen, air output from the pump, air filters on the pump, and the correct air pressure from the pump. The nozzle can also be dirty. Check for air leaks on the pump by spraying soapy water on the pump while the blower fan is running.
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Reddi heater 155 owners manual?
If this has a hot surface igniter, can you see it glowing? If not the igniter could be bad or the control
board for the igniter is baed.
If you are able, remover the igniter and hook it up to a 110 outlet, if it glows the problem is in the board.
If it has a board, follow the incoming power to line 1
and line 2. You will either have to splice the two leads
from the igniter into L1 and L2 or get a special spade
connector that can hold two leads on each terminal.
Plug unit in, glow coil should glow and unit should run
thats assuming you have that style of unit. Do not
attempt to do this unless you can safely perform this.
If you know of an electrician he can do this.
Jan 18, 2010 | Heating & Cooling
When plugg in fan turns about a 1 second and stops. Used to work fine last year actually used it couple times this year too what seems tobe the problem thank you
sounds like an ignition problem. The fan is supposed to start first to get the airflow going, then the igniter should heat up (glow igniters) or start sparking (spark plug igniters), then the fuel starts pumping. If the igniter is not working the fuel won't start. Things to check.... igniter - see if it is intact, fuse (usually in the circuit board), If those are ok, then check fuel pump, fuel filter, air filter. Hope this helps.
Jan 12, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
1997 VW JETTA DIESEL GLOW PLUGS
The glow plug relay is responsible for the duration of glow plugs, this needs to be the starting point. You should get a 12v out for so many seconds when ignition is switched on.
I have taken the cover off relays in the past, cleaned up the internals, sprayed with circuit cleaner and got plenty more years out of them, worth a try.
Nov 21, 2009 | 1997 Volkswagen Jetta
Pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Feb 02, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
64 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
