Too much red
My printer has started to print too much red particularly the skin tones are very pink.I use 3rd party inks which were ok and I've tried different ones since the problem started. The only thing I've changed is my computer which now has vista. There was no updated driver as it was "in the box". Do I need to change any settings or profiles?
Thanks
Zigger
Try going to the Color Management section, under Hardware in teh Control Panel.
On the devices tab, select the printer, tick the check box, and select 'Automatic' for Profile Selection.
Posted on Mar 12, 2008
Good question - it sounds like there are two possibilities:
1 - (and most likely), the other colors are low on your color cartridges, so it is printing out of balance. Can you check the ink balance and see what you have left? replacing the color cartridge will prob help a great deal.
2 - Check the properties on your printer, and see if something got tweaked with the Vista installation. Oftentimes, a new software installation will bump previous settings. You can often change many of the printer settings to a custom print, which might work much better for you.
Posted on Dec 30, 2007
Why is this EPSON STYLUS C88+ "Dura Brite Ultra" printer printing the wrong colors?
You have a corrupt or incorrect printer driver. Completely remove all references to the current driver from the computer. Un installing is not enough as the registry references remain. Then install the driver(s) again.
Jul 22, 2014 | Epson Stylus C88 InkJet Photo Printer
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
Ink does not stick to page on m2727 when printing cardstock. We have tried using different paper settings.
Are you using original HP toners or 3rd party (refills)? We have had issues with some 3rd party toners not bonding properly on heavier media. How heavy a cardstock are you trying to print on? If it is heavier than the highest rated paper for this printer then it may not bond at all, regardless of toner used. The heaviest paper that HP rates for this printer is 43 lb/bond. A lot of cardstock starts at around 65 lb/bond.
Jun 15, 2011 | HP Laserjet M2727nf Multifunction Printer
My hp deskjet 845c won't print pink. I've tried two different ink cartridges and no pink ink. Is my printer probably on it's last leg? I have also tried cleaning the print heads...didn't help.
Are you using HP factory new cartridges?
If you are using third party or worse, refilled cartridges, that may well be the cause of your proiblems.
Don
Feb 24, 2010 | HP DeskJet 845c Printer
Display shows there is no ink yet each cartridge has ink in it. And the printer will not print
Some printers are very particular about ink cartridges. Yours may be one. Even if YOU think there is ink in the cartridge, it may not be useable. The printer is not printing because, to protect itself from damage, it requires a certain level of ink to be present.
In my experience, for best results, use only genuine HP cartridges in your printer. Do not use 3rd party cartridges and please don't try to save a couple bucks by refilling your present cartridges.
Thanks for your interest in FixYa.com
Dec 26, 2009 | HP Photosmart C8180 All-in-One InkJet...
Printing too red
At this point I would offer that you bight the bullet and get a set of OEM Canon cartridges and do all the deep cleaning etc and see where that puts you. The third party cartridges may have caused some kind of problem, and not any "damage"
Nov 23, 2008 | Canon MX700 Office All-In-One InkJet...
No pink tone in skin tone
are you using genuine or compatible cartriges?
never use compatables for photos - keep them for documents etc
Nov 18, 2008 | Canon I900D InkJet Photo Printer
Posterization (orangeish) when printing skin tones
i would try useing cheper Premium paper the paper you are useing dose not like the ink ib your printer
Nov 06, 2008 | Epson Stylus Photo R2400 InkJet Printer
Skin tone
perhaps the nozzles and print heads need a thorough cleaning. from print manager, maintenance
Apr 02, 2008 | Canon Pixma MP800 All-In-One InkJet...
164 people viewed this question
k24674
jasbo
jasbo
