Question about Fossil AM 3688 Wrist Watch
Link removal on a fossil am 3688 thanks
  • 3 Answers
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
AM 3689 manual
and your question is?
Oct 05, 2012 | Fossil AM 3688 Wrist Watch
Make face flash on and off
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Apr 25, 2010 | Fossil AM 3688 Wrist Watch
Fossil links
Link
You can try contacting the Fossil's Authorized Dealer thru above link to further assist you.
Thank you.
Dec 30, 2009 | Fossil AU4003 Wristwatch
Fossil AM4200 shorten band
Depending on the age of the watch you will see indicators of pin direction on the inside of the band. Little arrows that point the direction the pins should come out. If there are no arrows you can look at the edge of the band. You are looking for a split in the pin that makes it look like a screw. The opposite side will be solid. You want to push on the side that is solid so the side that looked split comes out. This is a cotter pin and the split side is bigger and needs to come out first. Use a small punch to push the pins out. Make sure you take links from the band evenly on either side.
Jun 09, 2009 | Fossil AM 3688 Wrist Watch
Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Jan 26, 2009 | Fossil AM 3688 Wrist Watch
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Fossil ES1443, adding a link.
you can add links to this model , i would email fossil to and check if you can order some spare links.
ukenquiries@fossil.com.
the links have pins located on theside of the barcelet these can be pushed out.
Kind regards
Rob
Sep 17, 2017 | Watches
Watch band
Tools:
Procedure:
Dec 25, 2007 | Fossil AM 3688 Wrist Watch
Watch band
How can I remove a link from my watch band to fiit my wrist?
Dec 22, 2007 | Fossil AM 3688 Wrist Watch
Dead battery
take it to a qualifed watchmaker or send it to fossel.This watch is water resitant and MUST be tested to insure that it remain that way.
May 11, 2007 | Fossil AM 3688 Wrist Watch
Fossil AM 3688 Wrist Watch Logo
183 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
