Problem for GPS Devices
Generic problem for all GPS Devices
Unit will not power on.
The unit said the battery was low even when it was plugged in. Later, it would not power on. Does it need a replacement battery?
Comments:
Oct 20, 2009
- Magellan Roadmate 1412
Clarification Request
Posted by imbmetz1 on Oct 20, 2009
what model gps do you have?
Best Solution
posted on Oct 20, 2009
Rank: Guru
Expert
Rating: 90%, 389 votes
its probably not the battery, your gps should run even without a battery if the power port/circuit is ok. unfortunately this is a common problem that the usb port gets damaged with this and many other model of magellans gps systems.
if you had it plugged in to the car charger, make sure the green light is on while charging, if its not, you might have a blown fuse in the charger or the fuse for the cigarette adapter in the car.
if the green light is on, try letting it on for a few hours, then try and turn it on. if and when it turns on, you can verify if its charging by going to the system settings then the power option. the battery bar should turn green and move from right to left if its charging. if the battery is slightly low but the bar is not moving left to right, then its not charging.
you can check the charging by using the usb cable provided with your unit and hook it up to your computer to verify if its charging. but i suspect it has a bad power port (usb connector)
i hate to be the barer of bad news, because rarely do i get a good rating for being the barer of bad news, but hopefully you just have a bad charger or a blown fuse in your adapter or car.
good luck
bill
Was this helpful?1 person thought this was helpful
Popular Solutions for GPS Devices
Garmin StreetPilot C330 (010-00401-10) GPS Receiver
1 Solution
Questions and Unsolved Problems for GPS Devices
navigon GPS is awful!!!!!!!no assistance from anyone. I just need a humans contact on the telephone....
(More)
navigon GPS is awful!!!!!!!no assistance from anyone. I just need a humans contact on the telephone. I am not a compter whiz aand not everyone is. now i am stuck with this instrument. even my son-in-law could not get this started and he is pretty good.
Looking for a cross over gps system - I often drive to biking, hiking or kayaking spots and would...
(More)
Looking for a cross over gps system - I often drive to biking, hiking or kayaking spots and would like one gps compatible to use for road/trail and water.
I connected my Navman S80 to my computer to charge it and in the meantime I was clearing old files....
(More)
I connected my Navman S80 to my computer to charge it and in the meantime I was clearing old files. I accidentally deleted everything from the S80 and emptied the recycle bin. Is there any way to get the S80 running again?
mobilenavigator.exe exception:0xc0000005 address03fc39ac .?
can you update a nuvi 205w with truck height software
