Question about Sony VPL CS6 Multimedia Projector
Sony VPL CS6 in darkness !
The lamp on the projector stopped working and so wasreplaced... this did not solve the problem and am wondering if anyone has come across this type of problem or has any suggestions to get this great projector up and running again...
the projector powers up ... lens cover opens .... props itself up on its middle leg.... and after about 20-30 seconds winds down and closes lens cover ... all without the lamp powering up
things i have checked : continuity from the lamp socket to bulb... checked for voltage but was only 10v ac from the socket that the bulb housing connects to.... i just dont know what to look for next
thanks in advance to any one for checking this out
chris
  • G III Feb 21, 2008
    I replaced bulb followed the instructions: connected power cord and then on my remote pressed reset,left arrow, right arrow and then enter and I still have the same problem. I power it up the lens opens the stand rises and then goes into lamp/cover indicator light stays solid.
  • 52 Answers
Make sure the interlock switch is activated by the cover of the lamp.
Can't measure a voltage with the lamp cover open. High voltage is powering the lamp from an smps or ballast supply. If lamp is New, cover switch is good, then the lamp power supply could be faulty.
Siliconchip.
Posted on Dec 29, 2007
Same problem here too... any thoughts as to where I might be able to get a replacement power supply..?
thanks for the info so far.. atleast I have somewhere to start.
another chris
Posted on Dec 22, 2009
Acer P3150 lcd projector password-locked which was not earlier set, security card lost. Tried to input default numbers such as 1234 and 000000 but not working. Is there any solution to solve this problem?...
I found a solution that worked for me:
1. Turn on the projector
2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should word again
Jun 23, 2011 | Acer P3250 DLP Projector
I am getting a message on projector that fan stopped. what does that mean?
hi,
ur projectors lamp cooling fan have some problem. if the fan stopped the lamp will get over heated, that's why cooling fan is must. its a warning message if not it will create some problem to ur projector's lamp. u should use the projector only after solving the fan problem.
ok
Dec 17, 2010 | InFocus Office Equipment & Supplies
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
BENQ PB6110 - will not power on
Hi I am Vortash check the lamp housing is secure as most units have a safety switch on them to disconect the projector from the supply while a bulb is inserted .. I fthis is secure and the fuse is not blown I suspect the lamp or the ballast .. look for dry joints on the board for the lamp or unseated plugs other than that unless your friend can trace the psu switch mode power supply back to it's individual outputs and check that it is working correctly your going to have to take it to an engineer sorry .. hope this helps Regards Vortash
Apr 15, 2009 | BenQ PB6100 Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
Sanyo PLV 70 - Power Won't Turn On
it could that the plastic stem on the inside of the lamp cover on the underside of the projector may have snapped off. if it has you'll have to wedge something onto the cross shaped hole, to keep button inside the hole pressed in, in order for the projector to turn on
Sep 20, 2008 | Sanyo PLV 70 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
Sony VPL CS6 Multimedia Projector Logo
628 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
