Question about Ovens
Electric fan oven cuts out
Oven cuts out
  • Anonymous Mar 08, 2008
    When I switch lower oven with fan, the fan blade does not rotate. At one stage it rotated very very slowly and then eventually rotated properly.
  • 625 Answers
You mean a convection oven??
Posted on Dec 29, 2007
Stoves efa700h grill cuts out after around 20 mins, the grill gets very hot, read a cpl of posts about fans and thermo cut outs, easy job? appreciate any help
On the 720 there are two thermal cut outs. Looking at the wiring diagram, the cooling fan and the clock are the only two items that will run independant of the cut outs. So, is the cooling fan running ok or not? If it is and the grill is cutting out, then it could be the thermal cut out that has aged - or the fan may be running slowly because of age or there is a build up of dirt grease under and around the oven and on the outlets that stop air curculating properly.
If the fan isn't running then you need to replace it or the fan timer PCB may have failed. Once you have gotten into the oven's inards, you can test the fan to see if it runs or not.
Nov 16, 2010 | Stoves 720EF Electric Double Oven
Main oven switches itself off
sounds like cooling fan not working. check the fan and a limpet stat that switches it on. without the cooling fan the oven cabinet overheats and a safety cuts out the oven.safety stat could be faulty if no prob with other stuff.
Jul 20, 2010 | Electrolux EOU6330 Electric Double Oven
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
Oven Over Heat
Not sure if this is relevant but, have you set the clock correctly?  The oven will cut off if it's cooking on a timer.
May 01, 2009 | Smeg SE280X Stainless Steel Electric...
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
Cuts out over 100deg Celcius
the oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Jun 23, 2007 | Baumatic B180 Electric Single Oven
Ovens Logo
201 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
