Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Porjecter/laptop need to put a laptop thou a porjector how do i do it????
There should be a standard hook-up cable available for the back of your projector to your laptop. Go to your local computer shop and they will help you. You will need to know what configuration is on both the laptop and projector. ie. male or female connector. The laptop has a female connection mostly and so does the projector. Therefore you will need a double male if this is the case. God bless, Capt. Hannu
Posted on Jan 01, 2008
What are the lyrics to: Holy Spirit Thou Art Welcome in This Place?
Holy Spirit Thou art welcome in this place
Omnipotent Father of Mercy and Grace
Lord in Thy presence there's healing divine
No other power can save Lord, but Thine
Fill all the hungry and empty within
Restore us, oh Father revive us again
Oct 08, 2017 | The Computers & Internet
I need to know the actual gap to set the points.
depends on engine and # of cylinders.
Mar 19, 2015 | Cars & Trucks
Control panel key locked and remote lost
Hello
To relsese the key lock, set keylock of OFF, using remote control.
Pressing the [RETURN] button on the porjector for 10 seconds will release the 'key lock'. OK.
Nov 15, 2011 | Toshiba TDP EX20 Projector
How do you get it to turn pages from remote on a power point presentation? bwindsor
Hello
What is the model number and brand name of your porjector? Provide these details to me by Fixya, please.
Sep 22, 2011 | Vivitek D510 Projector
Hi, which area of the laptop i need to open to reveal the cmos battery. Thanks
Generally that would be the back of the laptop the section under your keyboard. It would help if you said which laptop thou.
Nov 25, 2010 | Computers & Internet
What is the right valve clearance for a 1979 suzuki gs850 i had to replace the head and cams but the shims are not in the head how do i check the clearance and at what cam position do i check them at
You need to put the shims in and fit the camswith all the caps and bolts on.
Then measure between the cam lobes and the shims with a feeler gauge, when the cam lobes high point is away from the shim bucket.
and write down all the measured clearances.
Then remove the cams and fit the correct thickness shims to get the clearance correct.
Fit the cams again and check, this can take a couple of tries if there were tight clearances in the first instance.
either fit the cam chain up each time to do both cams or make sure the pistons are only half way up the bore and do one cam at a time, to make sure the pistons and valves dont say hello.
cant help with exact clearance but a kawasaki 750 is 3-7 thou which will be pretty close as the shims let you adjust 2 thou at a time
ie if the measured clearance was 2 thou you would need a thinner shim to adjust the clearance to 4 thou
Jul 15, 2010 | Suzuki GS 750 Motorcycles
Wen i conented the projector it not porject to my gateway lap top
Connect the projector and hit your function (FN) key and tap the F8 key. This should toggle the display to the projector.
If that doesn't work, look at your FN keys (top row) and look for a blue label for CRT/LCD and use FN+ that key.
Oct 12, 2009 | Gateway M305CRV Notebook
Missing keys on laptop
hardware store or if u have a spare keyboard
remove the same from then thou b careful while putting then in laptop
May 19, 2008 | IBM ThinkPad T30 2366 Notebook
Porjector
Hi there
Is it a LCD or DLP ?
First try using a different cable. If the problem stil occurs this might be a faulty Mainboard - which would need either repair or replacement.
Does the discolouration show in the startup screen as well ?
Apr 17, 2008 | Office Equipment & Supplies
Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Mar 02, 2008 | Hitachi 60V500 60" Rear Projection...
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
90 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
