Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Konica Minolta Bizhub 600 Malfunction Detected C-2807.
Before the malfuction code is C-D203 now it's C-2807. I tried to reset "Reboot> press Utility> press Trouble reset> Reboot" several times. Sometime it fix the problem but after a few print jobs it won't print again. And I have to reset again. Any advice? Tech support is useless, call them several times they promise to come but its been 3 weeks and nobody came.
  • 167 Answers
You need a service guy to stop by. Resetting the machine is a temporary solution only. Service will be able to print reports and see where the issue lies if it goes beyond just fixing a part.
Posted on Jan 09, 2008
Queda espere calentamiento
Posted on May 15, 2012
Konica bizhub 600
Sir/Mam,
Thermistor 2 has detected a low or high temp. In the fuser the hot part. Mite want to have a tech look at it. clean it or replace it. to reset it once power of the machine from inside leave the power switch on the control panel on. hold down the utility/counter button turn on the machine wait to see trouble reset touch OK then power off wait ten seconds power up if it comes back do not reset again THE machine is trying to tell you there is a problem keep doing it will cost you a lot!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 21, 2014 | Konica Minolta Bizhub 600 750 Image...
Malfunction detected on KONICA MINOLTA Bizhub C220 trouble code: C-371
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Dec 24, 2013 | Konica Minolta Bizhub C220 Color...
Konica Minolta Bizhub 600 Malfunction Detected C-0203
Tray #2 Lift motor. Open the 2 draw check that there is not any paper in the back. if there is or was a small piece may have got stuck in the electrical connection at the back of the draw preventing the copier to raise the second draw.
Nov 19, 2013 | Konica Minolta Bizhub 600 750 Image...
Konica Minolta Bizhub 600 c-2101 code
C - 2101 The lock signal of the charging cleaning motor(mounted on the charge corona assembly) is not detected when a specified period of time elapses after is starts the backward operation from rear to front.
Remove the drum unit and remove the charge corona and rotate manually the cleaning pad,eventualy remove the cleaning motor and verify the gears.
If not reseting to Open /close the frontal door,try reset:
Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message ,release the Utility key and touch the message,then turn OFF the copier.Wait 1 minutes and turn ON.GOOD LUCK!
Mar 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
C 2807 error bizhub 750
Nov 15, 2012 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Milota Bizhub C250 Error Message
First power off the printer completely. Then power it back on while holding the UTILITY/COUNTER button. You will see the minolta logo, then you will see a troubleshoot reset button. Press it, you will see an OK result. Power off the printer again, then power it back on without holding the button and everything should work.
Aug 13, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
2,571 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
