Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer model 9134
I moved a year and a half ago and my sewing machine has been in storage until today. I got it out, threaded it and all but I can't seem t get the bobbin tension to be right. It keeps throwing out a ton of thread at the bobbin side. Any ideas on what is wrong?
  • 2 more comments
  • StakerBriz Feb 14, 2008
    My machine is doing the exact same thing...so when it sews there is tons of thread. I also have to put the needle down and not all the way in to even catch the bobbin thread. Any Help?
  • Danielle
    Danielle Sep 01, 2014
    My machine too. I rarely use it any more because of this.
  • Susan Kotarski Sep 02, 2014
    Machines that set a long time can accumulate dust. Old thread can also accumulate dust particles. Toss the spool of thread and remove the thread from the bobbin. If using a metal bobbin you need to inspect it for rust as well. Clean the bobbin with a machine oiled, lent free cloth and set aside. Make sure you are using the correct bobbin for your machine. Remove the bobbin casing and clean with an alcohol pad. Wipe the bobbin casing down with machine oil and the inside bobbin port that holds the casing. Needles can acquire micro specs of rust. Remove and toss the needle. Clean all surfaces of the outside cover of machine with a cotton ball dipped in alcohol, squeeze out excess alcohol. Clean the inside of machine. Turn off the power and remove the plates that cover of the feed dogs. Put the feed dogs in the down position (Darning), this gives you more room for cleaning between them. Using a couple of drops of machine oil on the tip of a brush clean feed dogs and the area around them. Use compressed air to blow out any unseen dust, broken thread, pet hair, etc. Return the feed dogs to the up position. Replace the feed dog plates making sure the screws are tight. Wipe the needle shaft down with a machine oiled lent free cloth using the hand wheel to turn it up and down. Replace bobbin casing into the machine matching the dots or marking correctly. Correctly install a new needle, install a newly wound bobbin (remember the thread must flow to the left side of the bobbin when placing bobbin into the casing. Rethread the machine with a new spool of thread. Check the tension with the foot in the raised position. It should pull easy through the eye of the needle but not loosely or tightly. If the needle bends when you pull the thread, the tension is too tight. Loosen the tension and try again. If you are still having problems with the machine then you should have a professional look at the machine.
    To add to my comment above...there is also a small spring type piece of metal that prevents the bobbin from turning too far. I call it a bobbin stop. This peice can get damaged when thread nesting occurs. Check to see if it is bent back too much to stop the bobbin from turning too much. If it is you can gently bend it back out into the correct position.
I had the same problem
it was stored in a garage (lots of heat) and i had a plastic bobbin
tons of thread on the bobbin side
so i bought new ones (brother brand) same problem
my friend pointed out the brand of bobbin makes a difference
so what the hek a couple more dollors before i toss the machine
and it worked when i bought singer brand bobbins
the heat must have shrank my first ones (like a shrinky dink )
your mileage may very
Posted on Jul 27, 2009
How do I sew a button hole on my singer 9134
Page 34 of the manual:
SINGER 9134 Instruction Manual Page 36
You can also search the web for sewing machine buttonhole instructions. There are a ton of web sites and videos available.
Oct 27, 2017 | Singer Sewing Machines
Needle wont move singer 478
I have a Kenmore sewing machine. I'ts about 30 to 40 years old. I have never had a problem with it until today. The needle got stuck down where bobbin is. I don't know if it should be seen by a pro. I can not get the needle out. The Bar on the side will not move either way. help...........!
Jul 06, 2013 | Singer Sewing Machines
SINGER MODEL NUMBER 9134 OWERS MANUAL
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9134 ) & click search
Mar 22, 2012 | Sewing Machines
Manual for singer sewing machine harmonie 300
The Singer Harmonie 300 is the USA Model 9134. You can download the PDF from this link, which is at the Singerco.com website: http://www.singerco.com/uploads/download/2d743e26f022a5a8d564c0fbeaad865bc4b7d00e.pdf
Jan 11, 2012 | Singer Sewing Machines
I HAVE AQUIRED A SINGER SEWING MACHINE MODEL #9134 AND NEED A MANUAL AS WELL AS PARTS. I WOULD APPRECIATE SOME ASSISTANCE.
A free, downloadable manual for the Singer #9134 can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006499L.pdf
Sears has an excellent, easy-to-use catalog of your machine's parts for sale. You can find those parts at: http://www.searspartsdirect.com/partsdirect/part-model/Singer-Parts/Sewing-Parts/Model-9134/1232/1220000
If you find that Sears is missing a part that you need, you can look up that part in this manual, record the serial number of the part, and continue your search at another authorized Singer retailer: http://parts.singerco.com/CPpartCharts/9_99999/9134.pdf
Good luck with the refurbishment of your newly acquired Singer!
May 18, 2011 | Singer Sewing Machines
The thread keeps wrapping around the bobbin case. I'd like to know what the bobbin case should look like on my singer 9134
You have not said what model you have whether or not it is self winding, metal or black plastic
Jul 16, 2010 | Singer Sewing Machines
I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Mar 06, 2010 | Singer Sewing Machines
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
931 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
