Question about Baby Gear
Help me fold this pram chassis please
Having stored this pram and chassis in her loft for some time ,my sister has put the chassis up and we cannot put it down again . It is supposed to have single handed easy operating
  • 2 more comments
  • nannyc Feb 10, 2008
    removed the pram body - then pushed down on handle which fold over the wheels - but I feel the handle should the fold somehow to make a smaller base
  • mmossyrock Feb 11, 2008
    I was given this stroller second hand and the first time I tried to fold it down, I wasn't able to. Is it supposed to fold by squeezing the red lever on the the side bar? I have tried that many times (with the hinge unlocked) and well as in combination with pushing the button and turning the handle. Does anyone have any experience with this stroller? Could the mechanism that causes it to fold be broken?
  • Anonymous Mar 31, 2008
    Stroller has a #l and #2 button which should make it fold up. I got this
    second hand but cannot fold the stroller. It is the Peg Perego Milano xl
    stroller. Thanks Sandy
  • Anonymous Mar 19, 2014
    Where are the levers etc to fold the pram
I had this same problem with a tag sale PegPerego Tender stroller. If its like mine you push the red button on the handle and twist it, and then step on the gray level on the lower left side near the hinge,
Posted on Jan 12, 2008
    Problem Solver:
  • 12 Answers
Haveyou tried oiling the the chassis. Since they have been in the loft for awhile.
Posted on Dec 29, 2007
Can't fold pram
Hi, I believe you activate the folding mechanism by pushing down on the two grey rectangular plastic buttons on the black side hubs (at the mid point of the pram).
In any case you can download the complete instruction manual for the pram for free at http://www.freebabymanuals.com/quinny/prams
Hope that helps.
May 26, 2010 | Quinny Buzz Jogger
I need a new chassis as the handle bar wont go down
You can purchase a new handle from the suppliers or the retailier where you purchased the pram as this is much cheaper.
Hope this helps.
Mar 09, 2010 | Quinny Buzz Jogger
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Cameleon 2006 known fault with Bugaboo
Your problem will be solved at www.buggypitstop.co.uk they will be able to repair your handle at faction of the price of a new one. They are Great.... oh ps speak to Fred good luck
Oct 08, 2009 | Bugaboo Cameleon Jogger
How do you put chicco travel system pushchair down
This is relatively straight forward.
Stand behind the pram, pull both triggers on the handles, and then pull the handle loop at the back of the pram which will then enable you to push the pram dowards and fold.
Practice a few times and you will be perfect within a very short time.
I hope this helps.
Oct 02, 2009 | Chicco C1 Trio Auto-Fix TS Iceberg...
I cannot fold the pram. Please help as the instructions are not helping me :(
If you try this without the seat/carrycot on the chassis to start with, this will be much easier.
Stand in front of the chassis, with the front wheel between your feet.
Push the left grey button down, and slide then pull the right-hand grey button. Whilst both buttons are depressed, push the chassis downwards towards the floor using your whole body weight. Then just check that the handle bar is at it's lowest height at this will make the chassis smaller for the carboot.
Depending on the chassis type you have, you will either have a grey lock that will keep the chassis closed, or a black nylon strap that will need to be clipped together to keep this closed.
Just practice a few times and you will get it.
I hope this helps.
Oct 02, 2009 | Quinny Buzz Jogger
How do i put a folded bebecar pram up to use
Press the central red button on the handle and twist on the twist grip. Place your foot on the horizontal bar (that the basket is attached to) and push down on that at the same time as pulling upwards on the handle, until the chassis is locked in.
You can obtain instructions for your Raider AT by e-mailing service@bebecar.co.uk
Aug 27, 2009 | Bebecar Raider AT Stroller
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
2nd hand BEBEcar Adventure raider AT+
Hi, I have just bought second hand the exact same pram. You have to push in the red button in the middle of the handle, then turn the handle down towards the floor. By putting a little pressure on it it should now start to fold down. Hope this helps.
I have my own dilemma though. When the carry cot is on as a forward facing pram, does the seat unit come off that you use for the buggy?
Apr 17, 2008 | Bebecar Raider AT Stroller
Baby Gear Logo
649 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
