Question about Sony RDR-HXD860 DVD Recorder/HDD Recorder
No program information on my sony HDX 560
When I go to system menu and set my program to record,everything is fine, on returning home I find that it has not recorded, I go back to system menu to find that all the programs ar reading no program information on the screen, I then check the programs on the TV and everything is OK. the arial first goes into the DVD recorder and then to the TV so this is not making sense, this problem can hapen more than once on the same night, record one and not the other. Please can you help!! ptrsmeth.
  • Don Zapfe Jan 02, 2008
    my sanyo 686 vcr records programs which I have to programmed it to record. Even though the menu reads empty it still records these programs. I've unplugged it for days and then done a new setup on it, but the same thing happens.
I had this problem. I found that when you record from the EPG it can change quite frequently. When this happenes then your recording will automatically get deleted. To sort this out I would use the Guide plus system on your box and then the problem wont occur any more
Posted on Jan 04, 2008
Request instrtuctions for setting Sony RDRVX560 clock
Do you mean the RDR-VX560 DVD recorder/VCR combo? With the original remote for the recorder, you need to press System Menu (which is the left button on the row of large buttons above the arrow key circle). Then use the arrow keys to select Setup, press Enter and then select Clock Set. (Press Stop before attempting to access the System Menu. Then make sure that the remote is in the same mode as the recorder. The Command Mode for the recorder is set from the system menu as well. The remote can be reset by pressing and holding Enter, then press and hold 1, 2, or 3. Hold both the enter and the digit listed for 3+ seconds.)
To provide more help, I need more information about your Digital Stream remote. I'm not sure if there is a button that will match the System Menu and the Command Mode on your remote. has a replacement original remote: . Other sites may also have the remote for sale.
The documentation for the unit is available from Sony support: . The direct link to the manual is .
I hope this helps.
Dec 05, 2011 | Audio Players & Recorders
How to find hidden settings of sony eericsson xperia x10
On the lock screen where you get the slide option, press the following buttons.
Home button(the middle one) > Back button> Back button> Home button> Back button> Home button> Home button> Back button
After you enter the combination, a new menu opens up giving you an option to choose fromService info, Service settings and Service tests.
In Service info, you can get information like Model number, Phone Software Version, IMEI number and the Working band/s.
In the Service Tests menu, you can test most of the physical components on your device. Its more like a diagnostic utility to see if everything is working fine.
Mar 05, 2011 | Sony Ericsson Cell Phones
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
• After timer recording is completed, the VCR turns off
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
Press SET –/+ to select one of
the program lines, then press
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
Aug 28, 2010 | JVC Televison & Video
How do you reformat the hard drive for hr-20/700
If you go into the DVR's Menu/Setup there will be menu selections to "Restart Receiver" and "Reset Receiver"
In the reset menu you should find three options "restart receiver" which is roughly equivalent (and possibly safer) than the reset button or a power cycle. "Reset defaults" will clear all of your preferences and personal setting without affecting recordings. "Reset Everything" pretty much returns the receiver to ground zero and deletes everything.
Apr 26, 2010 | Directv HR20-700
if it is only some programs, verify that your recording times are not overlapping and you are setting the timer for the correct times
Mar 17, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
SONY 560 change to DVD2 can not change to DVD3
Press and Hold Enter button and also Number 3 button for 3 second. After that press System Menu.
Aug 20, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
Leaves blank TV screen when Return button operated
It sounds as though the unit is actually recording a DVD, but is getting no incoming signal to record. What is your recording source? Satellite and receiver? Antenna? Cable box? In the set-up menu, be sure you have chosen the proper input source; i.e., recording from where? You may be able to access that menu through the Function button on the remote, AFter setting that menu, be sure to press Return to restore the recorder to the ready mode. If you are using the RF input for recording, be sure that is selected as well, as opposed to L1 or L2. The input channel must match the output channel on your receiver, usually channel 3 or four. What is the model number?
Dec 02, 2008 | Sony RDR-GX300 DVD Recorder
Sony Home theatre
at this time there is no region hack available for this model to my knowledge.
May 25, 2008 | Sony MHC-ZX70DVD System
Sony RDR-HXD860 DVD Recorder/HDD Recorder Logo
210 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
