Question about Saeco Royal Professional Espresso Machine
Water tank empty
I have just purchesed a Saeco Royal coffee machine second hand. After cleaning it, adding the beans and filling the water tank I switch it on and it runs a test telling me the water tank is empty when it isn't. I cannot go any further. Is there a valve or sensor not working or a simple solution to get it to recognise the water tank?
  • 2 more comments
  • Steve Dec 29, 2007
    There was a plastic weight that acts as a sensor that I did not know about. It was not inserted into the tank to track water levels. Thanks
  • chlatte Jan 21, 2008
    where is the sensor? the spring activated hole in the bottom of the tank works fine and water flows no problem.., have no idea where the "sensor" is?
  • Anonymous Mar 26, 2014
    Digital disply reads water tank is empty even though its full
    I am not using the coffee maker 7-8 month, How I empty the water from the heater ??
    Problem Solver:
  • 72 Answers
The sensor is not working.. try to identify the sensor inside the tank and change it..
Posted on Dec 29, 2007
Barista supremo thinks it doesn't have coffee beans The red light comes on, doesn't it? The light indicates that the water tank could be empty or the drip tray is full. Tell the coffee machine that it has enough beans, but to please the machine you will fill the water tank and empty the drip tray. Good luck, kolbrun
Sep 10, 2013 | Saeco Odea Giro Plus Coffee Maker
I installed an extenal waterline to my new saeco royal professional coffee bar machine however instead of the water filling the tank it is running inside and leaking out of the side of the machine. the...
The water line to the back of the machine does not fill the tank. There is a pressure reducer/ isolation valve inside at the water connection that switches between using the tank or outside line. Is it leaking a lot of water or just leaking a little? I have seen them get a crack from shipping. You can still use the water tank until you can get the situation fixed. There is a selection in the menu that you choose for which way you want to go. Direct connection or water tank. If you put water in the tank it will tell you that your tank is empty. You have to go into the menu and change it to direct connection OFF, push the menu button and then exit.
Jan 16, 2011 | Saeco Royal Professional Espresso Machine
New machine out of the box says "warming up" and that's all
Please check the connections on the board ( when you look from right hand side through the grill ) are all connected. It is possible one of the sensor wire is disconnected while in transport.
Jul 08, 2010 | Saeco Royal Professional Espresso Machine
Saeco Coffee machine water tank empty
It is possible that the water sensor on the back panel of the machine is not operating, you will have to remove the back panel and check the sensor with an ohmsmeter.
May 18, 2009 | Saeco Royal Digital Plus Coffee...
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Machine not working!!
the circuit board is probably fry when you put back the grinder the ajustment are sometime tricky maybe it grind the coffee to fine that why it doesnt drip good try that and if everything work fine except the water level so be it there probably something fryed in the board good luck cheers
Jan 22, 2008 | Saeco Royal Professional Espresso Machine
Royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
Dec 16, 2007 | Saeco Royal Professional Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
690 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
