My digital camara no longer wants to take pictures. The lens no longer goes back inside to the camara. And when i try to take a picture it gives me this code:R740-033. Is there a solution to my problem. Or do i just need to buy me a new camara.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the
camera may require professional repair.
New Batteries is not withstanding for longer time, i dont know why . Iam using insignia 7.0 pixel,...
(More)
New Batteries is not withstanding for longer time, i dont know why . Iam using insignia 7.0 pixel, when i connect to USB cable it is not showing any indication of hardware in system. Any one Kindly solve this problem
when i try to turn on hte camera, the green light flashes a few times but the objective does come...
(More)
when i try to turn on hte camera, the green light flashes a few times but the objective does come out and nothing happens
es que me manda un errro 740-033 y me dijeron que presionandole el reset de mi camara se le hiba a...
(More)
ES QUE ME MANDA UN ERRRO 740-033 Y ME DIJERON QUE PRESIONANDOLE EL RESET DE MI CAMARA SE LE HIBA A QUEDAR EL ERROR PERO EL RESET NO LO ENCUENTRO
