1,458 people viewed this problem
  • 1 person found this problem to be helpful.
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
1 Solution
This solution has been voted best by the Fixya Commnunity
The Sony VAIO CS-series Computer model has a known issue with its fan. If the fan is making abnormally loud noise and causing the Computer to shut off then service will be required. You can contact Sony Service Center to get the Computer repaired.
However, if the fan is not making loud noise but the Computer is shutting off automatically then possibly it may be a virus or the failure of the power supply unit. In this case, you may run complete system scan using an updated Antivirus program such as Norton to check for any potential threat. Furthermore, you can perform the C: Drive Restore using the VAIO Recovery Center or complete System recovery using the Recovery disc to ensure that the issue is not related to Software.
Follow the instructions given in the link below to access and use the various features of the VAIO Recovery Center:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1001992
Click on the sublinks given in the blue text on the page to view further information.
If the issue persists even after system recovery then the problem is related to the power supply unit.
4 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
There are many things that could be causing this problem: bad processor fan, processor failure, bad power supply - these are the more probable causes. There really is no way you are going to know until you take it to a shop and let them test it.
Source: my daughters sony vaio laptop will not turn on,
  • Was this solution helpful? Yes No
Author image
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
Source: Sony VAIO Laptop won't turn on. The power lights
Author image
take it to an expert... the fan is faulty
Source: Sony Vaio with loud fan and switches off
Author image
Properly Configure Time Zone
Make sure that you have properly configured the time and selected the right time zone. Configuring the time zone properly may fix clock that keeps resetting. To do so follow these steps:
  1. Click on Start
  2. Open Control Panel
  3. Click on Date and Time
  4. Click on Time Zone
  5. Select the right time zone by clicking the arrow below
  6. After selecting time zone don't forget to click "automatically adjust...."
  7. Click OK
Check CMOS Battery
There is battery named CMOS on the motherboard, if this battery becomes dead PC loses its date and time settings. Problem in battery may result in this issue. Replacing the battery with a new one is the best solution to fix the problem.
Install Windows Update
Some of the Windows updates also contain a patch to fix clock keeps resetting. To download and install latest Windows updates follow the steps below:
  1. Click on Start and open Control Panel
  2. Locate and click on Windows Update
  3. In the right panel click on Check for Updates
  4. Install the Updates
  5. Restart your computer
Repair Windows Registry
Mostly PC problems occur due to corrupt Windows registry. To fix clock keeps resetting problem you are required to fix registry error. You will need a good System Utilities program that includes a Registry Cleaning feature. Registry Cleaner deeply scans registry problems and fixes them instantly.
To download System Utilities program including a Registry Cleaner click here.
Scan System for Viruses
Attack by viruses or spywares on PC may also results in this problem. To fix this issue you have to completely scan your system for malicious or infected applications and clean all the files detected by antivirus program.
Download Clock Keeps Resetting Fix Tool
Source: sony vaio vgn-fs775p laptop real time clock not keeping time
Add your solution
Full Name
Top Sony PC Laptops Experts
Chris Hingee
  • Solutions: 32281
  • Level: 3
  • Achievements: 5
Romeet Barmeda
  • Solutions: 66
  • Level: 2
  • Achievements: 1
Sanath Kumar V
  • Solutions: 679
  • Level: 3
  • Achievements: 5
Expert Badge
Are you a Sony PC Laptop Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More VAIO VGN-CS215J/W Notebook Related Problems
Loading... Loading...
