Question about Sony DAV-SC5 System
COLORLESS PLAYING Hi there; I bought an sc-5 hometheatre 3 years ago and after a year troubles began: 1) When the system is turned-on : the LOGO is black and white(instead of blue) 2) NOW; if the film is "NTSC" after the insertion of the film the LOGO turns to normal blue and the menu and film would be normal(with color) ; BUT; if the film is "PAL", the LOGO remains "black and white" and the menu and movie go on in "black and white". I have tested my system with other TVs but it didn't solve the problem.
  • 10,594 Answers
Change the color system of your TV set n select Auto Color
Posted on May 29, 2008
Why do USB video's play through LG Plasma but not through Panasonic SC-BTT190 home theatre system?
Its really a software type problem i have a sony hometheatre that wont play certain videos. When tvs/home theatres are made they get whatever software that is put in witch most videos require the basic stuff sometimes its outdated or just not compatable.
Jan 02, 2013 | Panasonic Sc Btt190 3d Blu Ray Home...
Hi my 06 reconstructed cobalt has been giving me trouble lately. I noticed that the display started saying check charge system about a week ago and not long after that its started having trouble start
Sounds like nthe alt. needs to be replaced.
1/ start the car.
1/ remove the lug from the positive terminal and make shure it is isolated from grounding out.
3/ if the car stops running it's the alt. if not it is something else.
Dec 28, 2012 | 2006 Chevrolet Cobalt
I have psp 2004 and i bought it around year ago and couple of weeks ago when i was playing dantes inferno, analog began running down, without moving it. i put joysens plugin, and saw that analog was...
Analog sticks on the PSP do wear out depending on how heavily you use it, if its been more than a year since purchasing it, then you could buy a psp 2000 joystick from amazon and unscrew the faceplate and unscrew the current analog stick and then replace it.
Apr 18, 2010 | Video Game Consoles & Games
Dvd will not read
If purchased less than a year ago, it's under warranty. Get it replaced.
Warranties are normally for one year unless you bought an extended warranty. You should be OK.
Jul 07, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
It wont play dvds!!! Help!!! Panasonic SC-HT520
You can try a CD/DVD Cleaner Disk ($3-$5). Some sell for $15, don't know if you'll get better results. If it doesn't work, then you have a laser alignment issue that needs calibrating. The labor is likely to cost more than a new DVD player.
Dec 28, 2008 | Panasonic SC-HT520 System
TV warranty
Hi gince10,
I am sorry to hear that you are having trouble with your television. If you have enough information about the purchase, we may be able to locate the receipt for you. Simply visit your local store or call 1-888-BEST BUY™ (1-888-237-8289) for assistance.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 30, 2008 | Televison & Video
Unabl to play dvd
hi angedembe, guess your dvd lens is dirty or worn out.try using a dvd lens cleaning disk this might solve your problem n if it still of no use then u have to change your dvd lens.hope the 1st method solve your problem.have a nice time..
raj..
May 11, 2008 | RCA 420Watt 5-Disc DVD/CD Progressive Scan...
Samsung SC-MM10S Blue Screen
CCD sensor seems faulty . Samsung should repair free of charge.
Aug 28, 2007 | Samsung SC-MM10S Camcorder
Sc-HT80 Problem
Hi one solution to your probelom is that the lazer is underpowered.here is a fix it 4 u. A major problem began 2 years ago Some New DVDs would not always play. Message on LED display says "NO PLAY". I discovered today that the problem lies with the laser being underpowered for some DVDs. On the web I found a fix. Warning! Always have someone competent with electricity to fix the SA-HT80 with the following instructions: 1. Remove all disks from player. 2. When door is open slide front door cover upwards to remove. 3. Leave door open. 4. Important UNPLUG FROM THE MAINS! 5. Remove the 3 screws from under the front panel then remove cover screws. 6. Disconnect player from the mains. Remove cover. 7. Once you have removed the cover you will see on left side is the drive parts. 8. Pull out the two flat cables which go to the Drive from the vertical circuit Board(Hold the cable with thumb and forefinger close to the connector and slide the flat cables out of their connector. 9. Remove the screws fixing the drive unit to the base of the cabinet. 10. Now remove drive unit. 11. Placing the drive upright on a flat surface proceed to remove the two screws holding the Plastic bridge that sits over the disk. 12. Also undo the screw on the small circuit board which holds the disk sensor switch onto the bridge and unclip that small board. Remove this plastic bridge over the drive. 13. On underside of drive remove the two small screws from the drive circuit board. You can now gently prize this board loose.(There is some resistance as a plastic clasp is holing onto the underside.) 14. Turn Drive back to upright position. 15. Remove the screws which hold the drive in(Screws go through rubber mounts to cushion the drive). 16. Once you have loosened the drive look at the underside and you will see one flat cable goes to the Laser. Where this cable meets the metal part you will see a tiny device connected on the outside edge of the flat cable. 17. Turn the POT 1/5 off a turn clockwise(looks like a small washer and be gentle with it) I used pointed nose pliers for this. 18. Now reassemble DVD player. 19. Ensure cover is in place and screwed down before connecting to a power supply. This is a guide which you will follow at your own risk. Happy fixing Gerald
Sep 23, 2006 | Panasonic SC-HT80 System
Sony DAV-SC5 System Logo
81 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
