Question about DeLonghi Pinguino PAC-02 Air Conditioner
FX-160 not working
My Delonghi Fx-160 sits and works a s a fan when ti starts. Usually it starts cooling after a few minutes but on occasion it seems to just sit their with the fan runing not performing any cooling.
Restartign the device dosen't solve it, it just starts cooling randomly, usually after a few days.
There are no error messages displayed and the de-humidify function dosen't appear to operate during these 'events' either.
Anty ideas, it this a service issue or is it something overloading?
  • 1 more comment
  • menialmoose Jan 09, 2008
    Yeah, pretty much identical issue.
  • Anonymous Jan 10, 2008
    Our FX160 has the same problem. You run it and just get a fan. Other times it starts then cuts out but doesn't cut back in. There are no errors on the LED. The filters are not blocked. The water tank is empty. Restarted multiple times. There is not pattern to the problem other than it happens on really hot days, just when you need it most.
  • irishronnie Jan 07, 2009
    same problem just blows air....compressor not cutting in?
  • 236 Answers
Check your voltage in your area or check your outlet it may be loose. If your outlet is loose try using another outlet to test the unit.
May be the unit is tripping due to abnormal voltage or loose outlet.
Posted on Dec 29, 2007
How do you input minutes into the calculator. Yes, it displays degrees but not minutes like a TI help
Press the degrees/minutes/seconds [o ' "] button after entering each part of the angle. It will appear on the screen as the same (degree) symbol after each part, but the calculator will recognise that each part is different and compute accordingly.
Sep 05, 2011 | Casio FX-115ES Scientific Calculator
I have a blaney 100 fx quad bike. starts easily from cold and runs brilliantly. when you stop and idle for a few minutes it cuts out or if you switch it off it wont start again. if you let it sit for 45...
Your engine is staved by fuel check your pilot jet its clogged up this means a tiny percentage of fuel is getting into the bowl when the bowl is dry because your jets blocked it takes 45mins to fill back up because the blockage in jets,this should take seconds ti fill
Mar 06, 2011 | 2003 Suzuki AN 400 Skywave limited
What video cards are compatable
This computer comes with a Nvidia FX5200 so this tells me that it can support any AGP8X Graphics Card.
Here is a list of compatible GeForce cards for this PC's.
GeForce 6 Series - (GeForce 6200, GeForce 6600GT, GeForce 6600 and GeForce 6600 LE)
GeForce FX Series - (GeForce FX 5950 Ultra, GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900 XT, GeForce, GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE, GeForce FX 5200 Ultra, GeForce FX 5200 and GeForce FX 5500)
GeForce 4 Series - (GeForce 4 Ti and GeForce 4 MX)GeForce 3 Series - (GeForce 3, GeForce 3 Ti 500 and GeForce 3 Ti 200)
GeForce 2 Series - (GeForce 2 Ultra, GeForce 2 Ti, GeForce 2 Pro, GeForce 2 GTS and GeForce 2 MX series)
GeForce 256 Series - (All)
Here is a list of compatible ATI/AMD cards for this PC's.
ATI Radeon X Series - (ATI Radeon X1050, ATI Radeon X1300, ATI Radeon X1550, ATI Radeon X1600 and ATI Radeon X1650)
ATI Radeon 9xxx Series - (ATI Radeon 9550)
You should already have a GeForce FX5200 so better than that is the 6600 and 6600GT.
Feb 22, 2011 | Gateway 500XL PC Desktop
I have Behringer PMP 3000 2 channels not working fx not working and fan not working but unit turns on ok
Fan speed depends on temp sensors. If doesn't run at all when unit is loaded, take in for repair immediately.
If FX window changes with the control, chances are you have not set the controls properly. You need to havew THREE places turned up for effects: The FX knob in the desired channel(s), The FX slider and finally the knob to send the FX to the mains and/or monitors.
OFTEN the stereo channels aopear to not be working because of the A/B switch between the RCA and 1/4 inch jacks.
You did not give me enough info regarding which channels appear to not work.
Sep 26, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My daughter is starting 6th grade and they have asked her to get a T1-30XA or TI-83/TI-84, she is not advanced in math. Which on would you recommend ?
The Ti83/84PLUS are a lot more advanced than the TI-30XA because thaeu can graphs, statistics, calculus etc. But they lack a key for the % function, and a key for the fraction manipulation, the angle unit conversions (deg, radians, et grads) and they are a lot more expensive than the TI30XA.
Before your daughter finishes high school, you will eventually have to buy her a graphing calculator but right now a TI83/84Plus calculator seems like overkill. Besides some teachers may not let students have graphing calculators during exams.
Honestly I suggest you buy the TI-30XA Solar version. There are some new nifty calculators manufactured by Casio (Casio FX-115ES, FX-991ES, FX-300ES), Sharp (El-506W, 516W ). The beautiful thing about these new kinds of calculators is that you can configure them to use the Textbook display: equations and expressions can be entered as they would appear in textbooks. The Casios are called Natural Display and the Sharps are know as WriteView models.
In fairness to Texas Instruments, they too have calculators that incorporate that display format but I do not know the exact model numbers (maybe TI34XII multiview).
Aug 20, 2010 | Texas Instruments TI-30XA Calculator
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
How to calculate calculus problem by a scientific calculator fx-991ms
If by calculus problem you mean derivatives of functions, integrals, extrema and such things, I am sorry to inform you that neither the Casio FX-300MS, nor the FX-991MS can handle them. The newer Casio calculator FX-991ES is capable of performing numerical differentiations and integrations. There also graphing calculators by Casio FX-9750G, FX-9860G as well as by Texas Instruments (TI 83 PLUS/TI84PLUS) that are reasonably performant in that area.
Hope it helps.
Oct 19, 2009 | Casio FX-300MS Calculator
Casio fx-115ES shuts down after 6 minutes
Only manually. Press the shift or alpha key every few minutes, making sure they're in the right state before doing anything else. Each time you press a key the calculator restarts the 6-minute timeout.
Dec 14, 2008 | Casio FX-115ES Scientific Calculator
Crashing comp with nvidia geforce fx 5200
your agp video is overheating, see if the cooking fan attached in it is working fine.
Oct 27, 2008 | Nvidia Geforce FX 5200 Graphic Card
DeLonghi Pinguino PAC-02 Air Conditioner Logo
446 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
