Hoover 2305 washine machine wont spin
I have a hoover 2305 7kg washing machine and it just wont go into any spin cycle at all. I can switch it off for 12hrs and still nothing it will do every other cycle fine except spin. hoover 750 la washing machine,everything works except the spin cycle but it does work sometimes tried changing the elect motor did-nt fix the problem i suspect it may be an electrical problem maybe in the switch not sure
  • 3 more comments
  • geoffro Dec 31, 2007
    would it be possible to bridge the interlock switch to prove if this was the problem
    tried bridging the switch didnt fix the problem
  • Anonymous Mar 22, 2014
    my washing machine has power, and will go on spin cycle but wont do any wash cycles at all, does not look like any water is getting to the machine
  • Anonymous Mar 29, 2014
    Won't spin
  • Anonymous Apr 01, 2014
    knocking when on spin cycle
  • 183 Answers
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
    President:
  • 1,314 Answers
Change your door switch its a safty switch that prevents spin if lid or door is opened if it goes bad no spin look for a pib or plastic piece sticking out on lid to locate switch
  • robert samples Dec 31, 2007
    yes but if you have small kids dont leave it like that ask me how to get the case off if you dont know
Fitted new motor to a commander 7kg A6928 agitator spins but bowel stays still in spin setting why?
sounds like maybe a thrust bearing in the hub at bottom of agitator not engaging? are u saying the hub does not spin but the agitator moves?
Oct 31, 2014 | Hoover Washing Machines
My family 1600 hoover 7kg load wont stop its cycle and has been running for 2 days!!!!!!
hi, it sounds like the timer programme control could be the cause of this fault.also temperture control thermostat the heater and water inlet value are possibility hope it helps
regards
shaun
Nov 11, 2011 | Washing Machines
The 7kg hoover will wash then stop agitating
There can be many reasons why the machine does not agitate. If it does not complete the cycle, then it can be a problem with the timer control, see The cycle doesn't advance .
If cycle goes on, but does not agitate, it can be the agitator and more, see It doesn't agitate or There's no delicate or regular spin or agitate
Oct 08, 2008 | Hoover HTC243 Top Load Washer
Machine wont spin
try to check the pumpbelt maybe it is loosen already.. by opening the back cover of the washine machine you can see the motor with pumpbelt attached to it that makes the machine spin..
Sep 22, 2008 | Hoover Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
1,311 people viewed this question
Top Washing Machines Experts
