Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony triniton tv widescreen
I have a wide screen tv but for some reason my display has changed to 4:3 and I dont know how to change it back to 16:9
  • 934 Answers
It's called the aspect ratio - and on the WEGA design I think you've got a button on the remote labled picture mode.. If not or that doesn't work go into the menu and look for aspect or aspect ratio and rest that to 16:9...
Bill
Posted on Dec 29, 2007
How do i fix a too wide picture on my sony kdl40ex500?
Why are you using 4:3 letterbox? It might be the default aspect ratio but widescreen tvs should be set to 16:9 aspect ratio.
Aug 22, 2014 | Sony KDL40EX500 40 in. HD-Ready TV
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
Hi, I have a black sony KV32wf1u that I am hoping to sell but i am not sure whether this would be classed as a widescreen tv or not. Coulkd you help me pleased
SONY TRINITRON 32" KV-32WF1U, widescreen
SONY TRINITRON 32" KV-32WF1U, widescreen television with remote control, teletext, SCART connections.
That ad says wide screen.
Wide screen usually meant 16 X 9 aspect ratio, which I take it is your screen.
Tes, go for it, call it wide screen.
Feb 01, 2011 | Televison & Video
I have a Pioneer DV-525 DVD player, and recently upgraded from a 4:3 TV to a widescreen TV. However, under the Setup menu, it won't let me change the setting to 16:9. The options are grayed out, and I...
The DVD movie has to be a "widescreen" version...
Check the cover of your DVD movies ... there may be one or more widescreen DVD's in your collection...
That should work.
What widescreen TV did you get? Brand / model.
If it is Samsung ... on the remote, press the "p.size" button (and wait) ... continue pressing and waiting after each press to see if the Samsung will adjust ... You may get a distorted pic ... like very short and very wide people.
What TV Brand / model??
Sep 14, 2009 | Pioneer DV-525
MY TV WONT STAY ON WIDE MODE. wHEN THE ADVERTS COME ON IT CHANGES BACK TO HALF SIZE. I HAVE A NEW SONY BRAVIA
This is actually due to the signal format being sent down from the transmitters/broadcaster. They by defauly output 4:3 which your tuner in your TV interprets and rejigs it into 16:9. Te adverts as they come on are seen by the tuner in your tv as a change in aspect ratio, and therefore your TV is trying to best display these. However, if you go to your screen settings, you can change the screen auto format to your choice and this chould ensure that the picture always gets set to your choice. If set on default, it will vary between 'wide' and 'smart'.
Jun 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Screen size changes on its own
Use the format button to switch betwen auto, widescreen (16:9), letterbox (4:3), and other options. not all formats are available on all channels.
Fame !
Jun 23, 2009 | Televison & Video
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
546 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
