Question about D-Link DI-634M Wireless Router (DI634M)
Wireleess router wont start
I bought it today and i tried to install new firmware didn't work so i thought i would go to install hardware from hard disk and it said restarting router and then after a bit it said page cannot be shown and i reset it and i everything and still cant connect to the internet or even get into the router setting please help!!!
    Scholar:
  • 70 Answers
Actually the default for D-link is 192.168.0.1.... and admin is the username and leave the password blank...
Make sure your computer is plugged into a LAN port, not the WLAN. The WAN is typically used for connecting to the cable/DSL modem.
If nothing is working, reset the router to factory defaults. You do this by holding the reset button for 10 seconds while you turn it on. Reset button is on the rear of the unit.
Posted on Dec 31, 2007
  • Jeff Sapper
    Jeff Sapper Jan 08, 2008
    One thing I did forget to mention is your computer must be set to do DHCP or be on the same subnet as the router (when you do a hard router reset). So you address should be something like 192.168.0.x (x=2 thru 255). You can also check by getting to the command (cmd) prompt and typing in "ipconfig". You will see the IP addresses for your compter and router. On the IP addresses, the first 3 octets must match.
    Scholar:
  • 112 Answers
Try putting a cat5 cable from the computer's network port to a cat5 port on the router then on the computer open internet explorer in the address window type the following but use the IP address of the router "which is the Deaut Gateway" it will be on the bottom of the router and also in the manual that came with the router, http://192.168.2.1 -or- 198.168.1.1 use the username and password in the manual, the username will either be admin with password of 1234 -or- the username field will be left blank with the password of admin. after you logon the router's setup page you can configure the router as you desire. be sure and create the PPPOE internet connection on the router use the username and password that your internet provider gave you. BPCS
Posted on Dec 30, 2007
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
Printer connected to a Asus router RT-n56u via usb port System with Windows 7 Ultimate 64Bit Usb port enable through Asus Printer Utility Driver select (auto) during installation SAMSUNG UNIVERSAL PRINT...
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Jun 19, 2011 | Office Equipment & Supplies
My modem works fine with my old linksys router. I bought a dlink and I had to unplug my modem to get it to start working again. This would happen dozens of times a day or sometimes just once every day. I...
Ok, based in my research online, i found the following that might help, subbed into 2 possible solutions:
Solution 1: Install Router Commander. It seems to have worked well with most D-LINK installations and aside from reducing the intermittent connectivity, it will also help boost your performance for downloads and gaming.
Link: http://www.routercommander.com/
Solution 2: Check your router for it's model and the DLINK website for any firmware upgrades that might be necessary. If non are needed, try to reset the modem to factory default config and then re-configure or perform and upgrade to the firmware (if necessary). Follow the user manual provided for instructions on this or download it from the D-LINK website in a PDF file format.
If all else fails, the unit may be faulty and it would be best to either go back to the vendor you bought it from to request a replacement or call D-LINK directly (if unit is under warranty) to request for replacement.
Hope this helps!
Regards,
Technomancer
Oct 26, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a Belkin F5D8233-4v3 router. I can get just one wired port to work. I use both wireless and wired connections. Could this be a hardware or software problem?
That's a fairly new router, you shouldn't be having those issues. Make sure you're identifying the uplink port, the quickstart guide with router should help with that.
If everything is wired correctly, it could be either firmware of hardware. Might want to try calling Belkin or even where you bought it from to see if you can exchange. Sounds like you got a defective unit. Alternately, try going to Belkin's website and downloading and installing the latest firmware for the router. If that doesn't do it, then you have a hardware failure, and Belkin should owe you a new router, that router claims a lifetime warranty.
There is a new firmware v4, sounds like you have v3, check here:
http://en-us-support.belkin.com/app/answers/detail/a_id/521/kw/F5D8233/r_id/166
Feb 04, 2010 | Belkin Computers & Internet
Have maxtor bought today my pc wont reconise it
The drive needs to be installed and recognised and then formatted
go to start/control panel,add new hardware and let windows search for the hard drive.
if it cannot find it then opt for a manual installation and follow the instructions
Dec 09, 2008 | Computers & Internet
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Wireleess router wont work PLEASE HELP!!!!!
You will need to logon the router via the computer, and create a PPPOE internet connection. The user manual that came with the router will show you how to do this. If you do not have the manual. Do the following: open internet explorer in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway". once you get to the routers logon page enter one of the following: username "leave blank" - username " admin " -or- username "admin" - password 1234. once logged on the router go to internet connections and select PPPOE enter the username and password provided by your ISP save the settings and you should make the internet connection now. BPCS
Dec 30, 2007 | D-Link DI-634M Wireless Router (DI634M)
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
D-link 634M wireless router problem
Assuming wireless connection is enabled in the router(if you have the option), and it was set up initially through a RJ45 lead; make sure the router is not using 108 mbps streaming, as your laptop probably only has 54 mbps capability. See if you can set it to 54 mbps and re-start router.
Dec 11, 2006 | D-Link DI-634M Wireless Router (DI634M)
D-Link DI-634M Wireless Router (DI634M) Logo
100 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
