Question about Philips 55PP9401 55" Rear Projection Television
Philips 60pp9401 My television will click on and immediately turn off. Any thoughts on what might be wrong?
  • conyershelp Dec 29, 2007
    This was very helpful. Do you know how many 1.8 ohm resistors require repair?
  • 934 Answers
This set is made by Hitachi and uses two Stk392-110s for convergence amps. Usually when the amps fail the 24v line triggers the shutdown circuit. Replaced both Stk's and any or all of the 1.8 ohm resistor in that circuit as needed.
Posted on Dec 29, 2007
  • William Rayburn
    William Rayburn Dec 29, 2007
    Anywhere from 1 to 12 resistors - and btw you can also us STK392-150 Ic's for greater reliability.
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have 2 images on screen, turned the color all the way down, and still have 2 mages one with green.
most likely your convergeance IC is faulty , ( green color) , i had the same problem with my blue color , you need to replace it or have someone do it for you , ~~ 20 $ per ic .
Jan 13, 2010 | Philips 60PP9401 60" Rear Projection...
Philips 60PP9401 - red power led stays on all the time
you have a jamed relay or shorted relay driver transistor on power board
Aug 26, 2009 | Polaroid TLX-01911C LCD TV
Mystery dot
Its most likely dead pixels. This generally happens over a course of time. If its not too big that it irritates you, you could possibly let it go. Otherwise, it could call for a service job.
Jun 01, 2008 | Philips 60PP9401 60" Rear Projection...
Won't turn on
You have a bad regulator circuit in the power supply.
Apr 13, 2008 | Philips 60PP9401 60" Rear Projection...
Convergence problem on Philips 60PP9401
2.2 ohm 1 watt...................................T.
Nov 10, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 60pp9401
Yes,generic will work, mirror material is nothing special, just get
the size right................
Original problem is convergence you still need solution ? ...................................T.
Sep 17, 2007 | Philips 60PP9401 60" Rear Projection...
Phillips 60pp9401
This set uses two convergence packs that go bad and take with them a resistor or two. You will need a repar shop to get it fixed. If it's over 10 years old, I would suggest getting a new HDTV set as these sets can start going downhill fairly rapidly past this age. If that's not an option, the repair could run over $350 IMHO.
Dec 18, 2006 | Philips 60PP9401 60" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
