Computers & Internet Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a siemans gigaset se587 and i need to enable access to UDP 500 and UDP 4500. How do I do this?
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on Oct 23, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
29523
Points
257
You need to access your unit via it's web interface and go to the Firewall config. UDP is a one way protocol that needs to be able to operate, based on your information, through ports 500 and 4500. You should by default have this open on your LAN. If you need UDP access through the firewall to the WAN, you can allow those entries through the firewall. The manual should be able to walk you through this. Depending on what you are doing, you might need to open those ports on your computer also.
Siemens gigaset se587
read the router manual. then ask your question.
Router connection loss
Your router might have been reset and now the settings on your devices does not match that of the router. If you have wireless security enabled on your router make sure your devices are set up to match those settings.
Seimens Gigaset se587 ASDL Line speed goes
It turned out to be a phone line difficulty, not the modem. Seems there is a not so friendly mouse in my house. Thanks anyway. Live long and prosper.....
Gigaset SE587 networking adaptor
Any of the major manufacturers ie: Linksys, Belkin, D-Link Cnet etc. will work. Go to your local computer or office supply store and tell them the router that you have and they should be able to direct you in the right direction.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How to setup port forwarding on gigaset se587 router
Hi - You can get an online guide on the link below:
Gigaset se587
Please update the question & let us know if the information given was useful to you - Good Luck!
6helpful
4answers
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
Hi...unable to connect to ps3 using siemans gigaset se587 wireless router
hi there,
first you need to make sure u can access your wireless router with no problems and the wireless is turned on for your ps-3...then u need to forward some ports...
Turn on PS3 and goto Settings, Network Settings.
Select Internet Connections. If it asks you want to be disconnected select Yes. Select EASY. Select wireless
Select SCAN this will take a few minutes. The PS3 should find your router and already have the SSID# so just type in your WEP key. Select save and then wait a couple of minutes then select test. It should hook up.
If it hooks up with NAT3 then you will have to enable UPnP on you router. type in http://192.168.1.1 on your computers web browser.
username: admin
password: admin
Click on the advanced tab and then on Universal plug n play and then make sure both check boxes are marked.
Then on the PS3 make sure the UPnP is enabled also in the network settings.
This should give you network and NAT2.
please try this link for port forwarding help:-
http://www.portforward.com/english/routers/port_forwarding/Siemens/GigasetSE587/PS3_NAT_Type_3_to_2.htm
Grand Canyon Tech
Grand Canyon Tech
